First time buyer: Fully Rebuild GE Fit
Old Mar 13, 2022 | 05:02 AM
wuj15's Avatar
Dear fellow members,
I am looking to purchase a GE fit in Thailand. The car that i am looking at the moment comes with a fully rebuild engine. Original engine is 120,000km, and just finished a rebuild with 2000 km on it. I am a newbie when it comes to Jazz. Was hoping the veterans on the board would give me some pointers, The car specs are as follow:
MT 2017 177Hp (dynoed)
-Piston JE 73.5mm
-BC rod the original port opening retainer
-BC valve spring
NGK Spark Plug
IRI SERIES model
IRIWAY8 High Voltage
MSD Coil
ARP L15 cylinder head nut , Racing valve
bosch 550 injector
AEM high flow pump, pressure 340lph 40psi
BILLION aluminum radiator, 2 large compartments
68 degree water valve
OEM brand nippon thermostat
Cam LMN Stage 2
k24 60mm BRD manifold
Exedy single sport series clutch Control with
MaxxECU Sport box (can control electric tongue)
Original factory gray exterior
Prodrager pipe, walk 2.5 inches, header, middle, end
GAB SS shock, adjustable 32 levels.
TE28 wheels TR1 tires 195/55/15
Android touch screen
The machine has been newly assembled with a new overhaul, the whole machine has changed , bearings, crankcase seals/rubbers, O-rings, valve seals, gaskets, clutch bearings, oil pump, etc.
Z062FIT
Racing
65
Nov 21, 2021 09:48 AM
Z062FIT
Sep 26, 2020 07:18 PM
Perrenoud Fit
Aug 28, 2020 08:38 PM
Sid 6.7
Mar 7, 2009 06:02 AM
Sid 6.7
Jul 25, 2008 09:05 AM
