No power to radio
Old Oct 20, 2022 | 06:49 PM
Billy Fit's Avatar
No power to radio
I was fixing my vent selector switch behind dash, disconnected ground bolt to get dash/Radio panel out, I started car without ground, did I fry the radio, got no power, fuse is good
. Bill
Old Oct 21, 2022 | 12:44 AM
56chevydan's Avatar
I doubt you fried the radio. The fuse for the radio is #14 under the dash. It's a 7.5 amp fuse. The ground you disconnected was probably for the radio- and maybe the ground for other circuits too. As you probably know you need power and ground for an electrical circuit to work.
Try re-connecting that ground and see if the radio comes back on. If it doesn't come on, re-check the #14 fuse with a test light on both test spots on the face of the fuse, or with a continuity tester, with the ignition in the on position.
FYI: The radio may light back up when you re-establish the ground or replace the fuse, but you're going to need to input your security code into the radio for it to actually function again.
Billy Fit
Oct 24, 2022 05:13 PM
Crawly
Mar 15, 2020 02:35 AM
SubaruSlayer
Mar 26, 2019 09:25 AM
Indy62
Feb 23, 2015 10:53 AM
Fit freak242
Nov 6, 2013 10:44 PM
