Programming new keys
Old Jan 21, 2023 | 02:32 PM
SpageddyLee's Avatar
Exclamation Programming new keys
Hi all,
Got a new to me, 2012 Fit Sport, manual. Only came with one key. Bought two new blanks online, had the dealer cut them. I programmed them, successfully, or so I thought. Both of the new keys will lock and unlock the doors. But, the immobilizer system does not recognize them and while they both turn and start the car, it immediately shuts off. I can't find anything online about programming these things so that they can start and run the car, not just open the doors. Any help is appreciated! Thanks.
Old Jan 21, 2023 | 02:59 PM
rla217@'s Avatar
Instructional video:
from this post:
https://www.fitfreak.net/forums/2nd-...ition-key.html
Good luck!
Old Jan 21, 2023 | 07:52 PM
56chevydan's Avatar
There's another key programming that needs to be performed other than your door lock/ unlock function. I'm surprised the dealer didn't mention it when they cut the key for you. The chip in the new key needs to be programmed to work with the security system in your car. The dealer can do this step for you, or you can use a locksmith or some hardware stores' key cutting department for this programming. If you do a search on this forum this issue has been discussed a few times here. I hope this helps.
Old Jan 22, 2023 | 06:54 AM
Thanks! That's the part Im stuck on, was hoping there was a DIY solution. Appreciate the help!
Old Jan 22, 2023 | 07:22 PM
It did, did not realize there was another step that was not a DIY step. Thanks.
Old Jan 24, 2023 | 11:34 PM
56chevydan's Avatar
There's a lot of good useful info here: https://lost-car-keys-replacement.com/honda/program/
Oreogarage
Feb 2, 2022 10:11 PM
FlipsFit
Nov 20, 2019 05:46 PM
arkansasfit
Sep 15, 2019 04:37 AM
obaa996
Aug 10, 2017 01:51 PM
cheripowell
Jun 13, 2011 01:47 PM
