Installed new Ignitions Coils and Cylinder 4 keeps misfiring
Old Feb 10, 2023 | 04:40 PM
Kirbytrainnerd's Avatar
Last week I replaced all 4 ignition coils and it worked for the 1st drive but the 2nd decided to be a 3 cylinder, any advice I can fix this
Old Feb 10, 2023 | 05:20 PM
Pyts's Avatar
Is a misfire your only code?
Coils and injectors are electronic and have specific fault codes paired with them when they fail (excluding phantom misfires wherein a car should have other stuff wrong with its performance). What led you to replace coils? What other work has been done?
Old Feb 10, 2023 | 05:50 PM
misfire is the only code
i replace them as my old ones were failing
Old Feb 10, 2023 | 10:09 PM
keywestyakker's Avatar
Swap the coil from 3 with another cylinder. If the misfire follows, then you just have a bad new coil. If not, then you have another problem. Swap the spark plug and check your wiring.
Old Feb 10, 2023 | 10:11 PM
JDFit's Avatar
switch coils 3 & 4 and see if misfire switches cylinders. That will tell you if new coil is bad. Also, did you check if plugs were loose?
Old Feb 11, 2023 | 07:07 PM
cutsheal5's Avatar
It’s possible an injector has failed, have you tested them? The injectors should all read about 10ohms, also the injector clips should have 7.3 volts at key on engine off. If your readings are outside this range you have a failure, do not swap injectors around to test if this is the case you will ruin more than one.
here is a link where I discussed it further.
https://www.fitfreak.net/forums/2nd-...ml#post1463531
Old Feb 12, 2023 | 08:17 AM
Pyts's Avatar
I totally forgot that you went over this and corrected my ****. That was so cool!!
I wish I knew how to find voltage/ohm specs reliably. They can be hidden deep within specific troubleshooting procedures if they're anywhere.
One of the dudes I'm working for presently will not replace any more than the specific failed item. we already spent too much and he's gotta build up his savings. Just did a singular injector replacement for him in hopes of avoiding a 3am phone call.. I'm glad I kept reading here. It reminded me of what to do if he calls back anyways. Bonus: He already has a spare ECM in his trunk.
@cutsheal5 I am in your debt!
Old Feb 13, 2023 | 07:42 AM
jonshonda's Avatar
So you replaced the coils but not the plugs?
Old Feb 13, 2023 | 03:04 PM
sayama0411's Avatar
Did you use the Hitachi coils or the cheap ones?
I would have replaced the plugs at the same time.
NGK Ruthenium spark plugs are the way to go.
Old Feb 13, 2023 | 07:22 PM
cheap unfortunately (the hitachi pack costs almost $200) only 1 has failed for now so the others are ok for now
Jim kelly
Apr 27, 2020 01:44 AM
doctor J
Feb 19, 2017 08:13 PM
gak8998
Jun 21, 2013 02:05 AM
fitisbamf
Jul 28, 2011 05:50 PM
JFit317
Jul 7, 2009 04:48 AM
