Windshield Wiper Replacements Fit?
Old Feb 22, 2023 | 02:10 PM
pthompso99@yahoo.com's Avatar
Question Windshield Wiper Replacements Fit?
Just put on my second set of new tires, 2013 Honda Fit (base, automatic, hatch). Having on problem. Decided to have tire place (Discount Tire, where I got first set in 2016) put on new wipers. Initially they put in 26 in for driver and (what they say is) 14 in for passenger. But, I have noticed I get "gaps" and overall less wiping with these TPO-branded wipers. The did change out 26 in for 28, but still see less coverage.The old blades seemed to have better coverage. Any feedback will be appreciated.
Old Feb 22, 2023 | 04:33 PM
Frenzal's Avatar
I think OE blades are the best. Plus you can only replace the blade when needed. Super easy.
Old Feb 23, 2023 | 11:50 PM
SheldonWS12's Avatar
Agreed - genuine blades are the way to go, imo they look better (stock) and are a simple change. We replace ours minimum once a year.
Old Feb 24, 2023 | 02:29 AM
spotnz's Avatar
I'm using newly fitted non OEM wiper blades , which are miles better that the ones with it, when I bought the car. Everything, except the arm part bolted to the car is new. Being longer than what was needed, meant that I had to cut the excess off. Did you just change the rubber?
Old Feb 24, 2023 | 02:41 AM
mykizism's Avatar
I wish my car came with the OEM wipers.
Currently they are fitted with those "flexible" aftermarket blades. They "skip" on the upper portion of the wipe motion and make an awful sound on every cycle.
Old Feb 24, 2023 | 02:50 AM
spotnz's Avatar
my rubber bits have 2 steel reinforcing bars. One each on either side of the rubber. this https://www.supercheapauto.co.nz/blo...mechanical-new might help you choose a better set of wipers
Old Feb 24, 2023 | 11:13 AM
Frenzal's Avatar
Just buy OEM wipers at an online Honda dealer. Shouldn't be too expensive.
Old Feb 25, 2023 | 03:32 PM
Langelo DeMysterioso's Avatar
PIAA Silicone. The best wipers hands down.
I've used them for years on every one of my cars. They last longer and don't squeak. I'm using a 13 inch and 26 inch on my GE8. I modified a 13 inch for the back. On the front it leaves a tiny triangle on the bottom of the windscreen closer to the passenger side but I'm satisfied with the coverage.
Old Feb 26, 2023 | 09:37 AM
NWCH's Avatar
OEM Honda refills only. Aftermarket blades just don't perform as well as Honda parts do.
Old Feb 26, 2023 | 05:06 PM
spotnz's Avatar
agreed. They are a great alternative when a Honda dealer doesn't fit into your lifestyle. eg when that costs 5 times the alternatives, which do a superb job. I don't have a Honda dealer in town. The aftermarket ones I use, do the job to a standard I am comfortable with. With no noticeable missing bits.
Old Feb 27, 2023 | 09:40 AM
NWCH's Avatar
Then order them online. OEM Honda refills are cheap on amazon.
Old Feb 27, 2023 | 11:45 AM
Thanks for the feedback, Since I was dsunb (and didn't collect old parts from Discount Tire), I will have to buy the "whole" wiper. not justy blade.
Old Feb 27, 2023 | 11:46 AM
Yes, i know the very triagle you mentioned. I have it, with the "nominal" 14 inch after-marked TPO
Old Feb 27, 2023 | 11:47 AM
Yes. All bad for me.
Old Feb 27, 2023 | 11:48 AM
Unfortunarely, Discount Tire changed metal and rubber part.
Old Feb 28, 2023 | 09:24 AM
NWCH's Avatar
That is why you don't let those guys work on your car...
They take the good parts off, and replace it with bullshit aftermarket stuff that doesn't work as well. Because it makes them money.
evil_queen_lisa
Oct 17, 2019 10:11 AM
Bob Levine
Mar 31, 2018 04:10 AM
strmslvrfit
Jan 7, 2015 11:17 PM
shawnshank
Oct 19, 2013 04:45 AM
carloso
Mar 9, 2010 07:18 PM
