Diable clutch pedal interlock
Old Jul 25, 2023 | 12:38 PM
nik danger's Avatar
G'Day
If this question has been discussed before, then pardon me, (If it has, I can't find it).
How does one disable the clutch pedal interlock, in other words, I would like to not have to push clutch pedal down to start car.
I know there is someone out there in FitFreak land that knows how to do this.
Nik
Old Jul 25, 2023 | 01:27 PM
Frenzal's Avatar
It's a safety feature so if you start the car in gear, it won't roll right away!
Old Jul 25, 2023 | 05:23 PM
nik danger's Avatar
I appreciate your answer, but I knew it's function already 2 decades ago.
Old Jul 28, 2023 | 09:17 PM
mykizism's Avatar
And 2 decades later you can't figure out how to bypass the clutch switch?
Old Jul 29, 2023 | 04:48 PM
nik danger's Avatar
Whoa... You got me there! There is a difference between knowing something and taking that knowledge and applying it. I am in the former camp. So, no don't know how to disable the neutral safety switch aka the clutch interlock switch.
Is this some kind of comedy forum?
Old Jul 29, 2023 | 08:55 PM
mykizism's Avatar
There should be a 2 pin switch at the top of your clutch pedal. If you want to disable that just complete the circuit. Like you said in your other post you will lose cruise control. 2015Lx said you can wire it to a toggle switch so you can switch it on and off as you like.
Old Jul 30, 2023 | 09:48 AM
nik danger's Avatar
2015LXFIT said, "May be able to have a hon-data tech take care of that but I'm not sure."
I don't know what having a hon-data tech take care of my issue means???
Could someone translate this helpful post into plain english?
NIK
Old Jul 30, 2023 | 06:47 PM
mykizism's Avatar
NIK
Pretty sure his auto correct did that.. he probably meant to say have a "honda tech" take care of it.. which it probably auto corrected to "hon-data tech". He probably works with hondata on a regular basis.
Old Aug 2, 2023 | 09:51 AM
nik danger's Avatar
What is a honda tech - Like a dealer service dept or something else?
Old Aug 5, 2023 | 09:13 PM
GrE8_Fit's Avatar
Yeah, a tech that works for and was trained by Honda.
I like the "complete the circuit" idea.
RD36
Jan 4, 2021 05:17 PM
FTBT
Oct 14, 2019 08:41 PM
Sono
Jan 29, 2018 07:54 AM
JaStonE
Oct 5, 2012 08:36 PM
Occam
Oct 3, 2010 06:01 PM
