Idle ticking noise 2009 95,000 mi
Old Dec 11, 2023 | 03:38 PM
Blackfitge2's Avatar
I've been having a ticking noise on idle the noise goes away when at higher rpm it definitely doesn't sound like lifter tick or a spun bearing any idea what it might be. I'm gonna check the exhaust heat shield later today when it's cooled off but I'm just hoping it's not something serious.
Thanks for the help
Old Dec 12, 2023 | 06:03 AM
Frenzal's Avatar
Have your valves been adjusted?
Old Dec 13, 2023 | 06:35 PM
Found the source of the noise my cat has started to rust loose so no major issue thanks for the suggestion tho
Old Dec 15, 2023 | 04:21 AM
SiXiam's Avatar
My catalytic converter recently got a hole in it. so I changed that and the middle muffler (which had a bad looking flange). My Fit has 110k miles. Was able to reuse the oxygen sensor. Tried a cheap replacement, but it gave me a check engine light. Also it was so cheap it was very hard to remove and was falling apart only in there a week.
MagicGuitar
Oct 13, 2015 05:14 PM
Mister Coffee
Nov 27, 2014 10:29 AM
fujisawa
Aug 7, 2012 05:52 PM
Elias
Mar 10, 2009 11:34 PM
