My moms 2013 honda fit is stalling
Old Dec 18, 2023 | 09:22 PM
tonyvillegas's Avatar
So my mom was driving her Fit today and it started stalling on her. I ended up taking it to a local auto parts store where they offer to check vehicles for free. I thought it was going to be an ignition coil, as it sounded very similar because it had done it in the past. Well, this time the computer threw out 3 codes, but it was for the ABS Brake system.
83-11 PCM (PGM-Fi) Malfunction. PCM Malfunction (Engine)
68-11 Brake Pedal Position Switch Stuck off
61-11 this one didn't have any description.
Hs anyone here experienced these codes as well? and if so did you find a fix?
I'm trying to avoid taking it to the stealership. Thank you in advance
Old Dec 19, 2023 | 06:04 AM
Frenzal's Avatar
61-11 seems to be a "low voltage" fault from a google search...
Old Dec 25, 2023 | 07:51 PM
SiXiam's Avatar
Battery, alternator or a poor ground is what I would check first. ABS will give codes with low power.
Sassy42
Jan 9, 2023 03:49 PM
wendylou
Mar 20, 2021 04:57 PM
doctor J
Oct 21, 2016 10:41 AM
Tealer
Jun 20, 2014 12:52 PM
ommegga
Apr 22, 2013 06:35 AM
