Strange sound coming from engine
Old Mar 18, 2024 | 11:14 AM
Mikeybg's Avatar
Good morning! The past week my fit has been making a strange ticking noise. I took it in for an oil change but that didn't change anything. This morning there was a misfire triggered by a check engine light. The code was p0303. Now a new noise this morning when I went to go start it. I will post a video. I'm going to take it to the dealership shortly but figured I would post it here to see if I should even bother trying to get it repaired or not. https://streamable.com/vo6qvr
Old Mar 18, 2024 | 11:39 AM
Drew21's Avatar
You might be suffering from a loose spark plug, with the new noise you're hearing being the result of compressed air/fuel escaping from the cylinder around the threads the spark plug is screwed into. The misfire, check engine like, and code all fit this scenario.
If a loose plug is your problem, at this stage you may have minimal damage - perhaps nothing or maybe just damage to the coil pack on that spark plug. If the spark plug comes out completely and damages the threads in the head, repair costs can go up quickly.
There are many posts here about loose spark plugs and blown out spark plugs. Also plenty of videos on Youtube.
As it seems like you've caught the problem before the plug blows out and causes real damage it would be wise to stop driving the car until you get it fixed. Every time you drive the car you take the risk that the plug will blow out.
Old Mar 18, 2024 | 11:43 AM
Mikeybg's Avatar
Let me try a YouTube link.
Old Mar 18, 2024 | 11:47 AM
Mikeybg's Avatar
Let me see if I can check for that. I hope it's that simple
Old Mar 18, 2024 | 05:01 PM
PK86's Avatar
It could be. Fix it because it will get worse quickly!
Old Mar 19, 2024 | 12:48 PM
Mikeybg's Avatar
It was the plugs. replaced them and we are 100%!!
Thanks again everyone!!!!!
victorampereira@gmail.com
May 19, 2026 12:24 PM
henmel
Jul 29, 2022 01:19 PM
ck42
Jan 4, 2020 04:35 PM
champikasam
Apr 16, 2017 01:17 PM
pilotamis
Mar 15, 2017 02:20 PM
