Transmission code P0718
Old Oct 12, 2025 | 10:43 PM
2009fitsprt's Avatar
Trans Started to shudder a bit engine light came on on got code p0718 at 118k so I Replaced both speed sensors. The engine light went away but still shudders a bit coming out of low gears or overdrive. I changed the Trans oil and used Castro universal full synthetic back at 116k. Oil look clean.
does it take a little time for this to correct itself?
Should I change the oil and again and use Honda ATF-DW1 oil? Or just save the money for a rebuild and drive it easy?
Old Oct 27, 2025 | 12:28 PM
zcargo's Avatar
I think it is a general consensus to use only Honda ATF in Honda ATs. Maybe multiple drain and fills between short driving periods in between. There is a procedure post somewhere on here where one could disconnect transmission lines to more quickly "rotate" the old fluid out and the new fluid in. I have no idea if this would correct your issue.
Mark
gonefitten
Apr 13, 2018 09:26 PM
CoryP
Apr 4, 2016 09:03 AM
Zetto
May 6, 2015 10:32 PM
xwikedonex
Sep 2, 2010 11:44 PM
FELIXY69
Feb 13, 2009 10:49 PM
