hatchback unlocks with the keyfob but won't allow remote locking
Old Oct 30, 2025 | 07:25 PM
olivermarks's Avatar
I have a new tailgate on my collision damaged car, everything works fine now: hatchback handle works to open it, if I double click the key for central unlocking everything unlocks, including the hatchback.
The central locking won't work though, I have to lock the car with the key. The door open idiot light is always on in the car and this slowly drains the battery over two or three days if the car isn't used.
I'm assuming the sensor in the lock is not triggered, maybe something is just slightly off when the lock closes around the lower body shell hoop.
I've swapped out the lock in the replacement tailgate for the original one but have the same issue with both.
The sensor trigger is hidden inside the latch assembly so I can't see what needs to be adjusted.
The closing latch seems to have two positions with the second one 'fully closed' ie just a small circle to encircle the loop metal. I'm assuming maybe my car locks in the first partially closed position but can't achieve the second tighter enclosure.
Has anyone pulled the latch apart by drilling out the rivets? I need to figure out how to get the sensor to be triggered so remote central locking works again and the open door light off.
I may push the body in a fraction with a portapower to see if that gets it to line up tighter but don't want to cause more problems, knowing where the sensor is and how it works would help.
Old Oct 30, 2025 | 10:06 PM
bobski's Avatar
Door and hatch latch loops are usually adjustable. The mounting screws (JIS +3, though Phillips 3 sort of works) go into a plate on the back side of the sheet metal - loosen the screws to slide the latch + plate around within the sheet metal cutouts for the screws.
Also, the rubber bumpers between the door/hatch and body are often adjustable. If one or more bumpers are extended too far, they may be preventing the hatch from closing far enough to fully latch. Turn the bumper like a screw to shorten or extend it.
Old Oct 31, 2025 | 07:48 AM
zcargo's Avatar
Try fully latching (2nd click) the hatch latch with a screwdriver or suitable device while the hatch is open. See if the hatch locks/unlocks as expected while the hatch remains open. This will tell you if your suspicion of the hatch not closing fully is correct. If this is the case, adjust the striker accordingly as stated by @bobski .
Mark
Old Oct 31, 2025 | 02:55 PM
The problem I have is that the two screws holding down the striker loop just refuse to release and the hatchback lock is positioned to be only in one location. I do have a JIS +3 strikeable impact screwdriver for Honda brake rotors, maybe I'll try wailing on the two screws with that. I was worried about chewing the screw + up and causing more problems. I'd apply heat but the gas tank is right underneath. I also have an induction bolt heater, maybe I'll try that too.
When the hatchback is open and I've fully closed the lock into position 2 fully closed, automatic locking with the key fob works. It always works with unlocking regardless, so it has to be a minor positioning issue with the striker plate and not the lock. Thanks for the input!
Old Oct 31, 2025 | 03:02 PM
zcargo's Avatar
FWIW, the gas tank is under the front seats.
Old Oct 31, 2025 | 03:06 PM
that's good news! Maybe I can get the flamethrower out after all! Thanks for the help
Old Oct 31, 2025 | 03:10 PM
zcargo's Avatar
I'd also throw it out there that after looking at mine, I'd surmise that the adjustment of the top hinges could impede the latch from fully latching; not allowing the hatch to sit "flush" with the back of the car.
Mark
Old Oct 31, 2025 | 03:15 PM
Mark
Thanks I'll check that, i did pull out a pretty big dent that didn't get anywhere near the lock area on the 'new' tailgate, unlike the suv bumper below numberplate hit that distorted the old tailgate. It all sits flush, gaps are good but i'll measure anyway.
These cars are pretty vulnerable to taller vehicles , which is most of them where I live.
Old Oct 31, 2025 | 03:52 PM
Drew21's Avatar
Every car I have ever owned has been vulnerable to taller vehicles. That's the "price" of driving economy hatchbacks when most drivers think they're only safe and/or fully displaying their alpha male status by running oversized tires on their oversized SUVs and trucks.
I can't even begin to count how many times someone in a lifted SUV/truck has tried to merge or turn into the space that my (apparently) invisible Fit occupies in the world. Luckily the Fit is pretty maneuverable and, fittingly for Halloween, I remain undead.
shesaidred
Dec 15, 2024 07:46 PM
spookyneo
Oct 22, 2024 12:06 PM
Ultrawolf
Feb 23, 2023 03:24 PM
LVFit
Jun 21, 2016 07:07 PM
Aviator902S
Mar 24, 2010 06:16 PM
