Is any lowering possible with 205/50R16 on a 2009 Sport and +42 offset?
Old Mar 11, 2026 | 06:40 PM
Bugger's Avatar
2010 Sport
16x7 48mm offset Advan RGD2
205/50 R16 Advan Neova tires
Bilstien Coil overs set at 2 finger gap
SPC camber bolts maxed out negative 1.5 degrees negative
Fronts rub under hard cornering and harsh bumps while turning. The sidewall are very square on this tire.
Old Mar 23, 2026 | 05:56 PM
Rudeboy03's Avatar
Originally Posted by thatwhitetsx
Swift Springs
16x7 +45 sq
205/50/r16
sits flush with the fender.
no rubbing under full load and lock, about a fingers gap between the tire and fender.
let me know if you have anymore questions
Did you need to cut bump stops when installing swift springs?
isis07734
May 15, 2012 04:16 PM
krazEkid
Apr 4, 2011 04:04 PM
Azizul Zulzaha
Mar 22, 2011 01:01 AM
tokenasianguy69
13
Sep 2, 2010 01:11 PM
kevinkidstar138
Jun 20, 2010 08:24 PM
