Jacking Points
Old Mar 8, 2009 | 03:55 PM
  #41
care for a pint's Avatar
Originally Posted by care for a pint
I ended up using jack point "B". I rolled the car on 2x4s and jacked it up no problem. This was my first tire rotation without using a lift or pnumatic tools. Went super smooth and got it done in about 1/2 hour.
Here's a shot on the stands:
Thanks for everyone's help!
Old Mar 9, 2009 | 08:37 AM
  #42
BakedCookies's Avatar
I had no problem reaching "B" with my jack this weekend. its a Napa 4.5 Ton.
Old Mar 9, 2009 | 05:40 PM
  #43
Alpha Zero's Avatar
Or you can jack up your car slightly with another jack on the sides before sliding the main jack under the front.
Used to have to do that all the time with lowered cars anyway.
Old Mar 9, 2009 | 07:09 PM
  #44
whyzor's Avatar
Thanks for the info. Just as a tip I used to rotate tires with 2 jack stands and 1 hydraulic jack. I lifted the front from center, put 2 jack stands behind front 2 wheels, then took off FR wheel, used hydraulic jack to lift RR wheel and put original FR wheel under there. Then moved to LF wheel, then LR, and finally back to RF again. Basically I used hydraulic jack to change the rear wheels while the 2 stands keep the front ones up. Spared me from having to get 2 more jack stands.
Old Mar 10, 2009 | 05:21 PM
  #45
i only do a front to back rotation on my GD so i just lift the front and the rear lifts up with it (endura tech has shorter piston shafts).
Old Apr 10, 2009 | 08:57 AM
  #46
badself's Avatar
Is the frame rail that stops right before the gas tank suitable to jack up one side at a time? I want to do a front-to-back tire rotation, and the dedicated jacking points discussed on this thread lift the front or the rear, but not a whole side.
Old Apr 18, 2009 | 02:07 PM
  #47
awptickes's Avatar
badself: I want to say no. What I would do is put the car on jack stands on that one side, or use two jacks.
Just to give some veracity to the claim that you shouldn't use the tow-hook:
Old Mar 29, 2011 | 01:56 AM
  #48
travman's Avatar
Originally Posted by mole177
the front frame is WAY deep... can't reach it with the best of jacks.
i've done the rear jack point and sides...
I've done the same. Is there any disadvantage of jacking up from the rear jack point then front left and the front right?
Old Jul 18, 2016 | 08:37 PM
  #49
Alco RS-1's Avatar
I think that this is the front lifting point on my 2013 Fit (GE8)
Here's another view of what I think is the front lifting point on my 2013 Fit. It looks right -- that's a beefy looking crossmember.
Attached Thumbnails Jacking Points-1-80-2016_07_17_honda_fit_front_center_lift_point_guess_with_circle_for_upload_ba0c5a3c60db23152.jpg
Greendog
Jul 9, 2016 07:06 AM
sharkytm
Jul 5, 2012 03:41 PM
ericman20
Mar 29, 2008 08:09 AM
Illusive
Sep 9, 2007 07:16 PM
crozewski
May 4, 2006 12:23 AM
