windows rattle when slightly open?
Old Apr 1, 2009 | 10:37 AM
panda1314's Avatar
i just noticed this recently (spring is here and finally drive with windows down) when i open the windows slightly (an inch or 2 down) the windows rattle whenever i go over bumps. its a very nerve racking rattle. as if its almost going to fall right down into the door or something (i've seen it happen when i worked at toyota before. Anybody else experienced this problem before? the only time i had my doors taken apart was when i had them b-quieted (dynamat knock-off).
Old Apr 1, 2009 | 11:05 AM
reako's Avatar
I don't believe mine rattle like that...at least I haven't noticed it, especially as bad as your describing. Is it possible you put your doors back together wrong when you had them apart?
Old Apr 1, 2009 | 11:20 AM
txmatt's Avatar
Mine rattle like this, too. Not really loud, but annoying.
Old Apr 1, 2009 | 11:36 AM
JDM_DOHC_SiR's Avatar
My windows had this problem... untill I put sound deading on my front doors.. it curred 90% of the problem...
The plastic guide in the window track seems to be the problem...
Old Apr 1, 2009 | 12:09 PM
panda1314's Avatar
ok so maybe im not the only one...unfortunately i didn't do the work on sound deadening my doors. I had a local reputable audio shop doing it. Oh well guess I'll just have to live with it then.
Old Apr 1, 2009 | 02:15 PM
spin out's Avatar
ive been whining about this for months.
all the windows rattle when partially down... and if i hit a bump it sounds like the window could literally dislodge.
having the windows 2/3rds down (or more) helps.
my driver's side window rattles a bit when all the way up.
it's annoying.
Old Apr 1, 2009 | 02:38 PM
wskwong's Avatar
mine does that too....
so i roll it further down and it seems to be ok....
Old Apr 1, 2009 | 02:49 PM
cardinal's Avatar
Same here.
With spring time and partially opened windows, I've got rattle. Was annoying, so I closed windows and turned on AC.
To Spinout: I just tried again to Rep you but was refused. The same thing happened months ago. Maybe your blacklisted? lol
Old Apr 1, 2009 | 03:12 PM
BakedCookies's Avatar
mine do it as well, especially noticeable after lowering the car
Old Apr 1, 2009 | 06:40 PM
cyergey's Avatar
+1 Passenger window was down about 1 to 2 inches and after a minute of it rattling, I closed it and turned on the vent with cool air.
Old Apr 1, 2009 | 08:25 PM
TWGE08's Avatar
Do you have any more details or pics on this? I want to fix this when I install my speakers.
Old Apr 1, 2009 | 08:38 PM
McGurk's Avatar
Mine rattle too, but not too bad. Anybody have any luck getting help from Honda about squeeks or rattles?
Old Apr 3, 2009 | 03:32 AM
joemama4646's Avatar
Whew! I thought that it was just my car that was doing that... I do agree about after lowering it, the windows rattle more so than when at stock height
Old Apr 4, 2009 | 01:49 PM
chuckm1020's Avatar
yah nothing to worry about. mine rattles also. If you think the fit was bad. My evo was 10 times worse.
Old Apr 4, 2009 | 03:07 PM
dtmbmw325i's Avatar
+1 my fit does the same. Also my 05 Accord had this issue. I believe it is a Honda fault with there windows
Old Apr 4, 2009 | 11:39 PM
cab0053's Avatar
nope
haudoodles
Sep 25, 2014 10:38 AM
frogster
Jul 16, 2014 05:27 AM
sooznd
Jul 8, 2010 09:32 AM
bobthenuke
Jul 19, 2006 06:16 AM
benfal2001
May 24, 2006 12:48 AM
