off sets????
Old May 19, 2009 | 07:54 PM
AztecDude's Avatar
Question off sets????
I need some help trying to understand how the off set works,here is a example of what i dont understand, if I pick a set of wheel 16x7 +45 that mean is gona be right on the edge of the fender or is gonna be more towars the inside of the render? so any help i can get to try to understand this is so much welcome,thank's
Old May 19, 2009 | 08:38 PM
stevet47's Avatar
The more positive the number the more tucked in it will be. The more negative the number the larger the lip and the further it will stick out.
Wheel Tech - Offset
Wheel Offset Calculator
Old May 20, 2009 | 12:47 AM
it's pronounced iVTEC's Avatar
just a quick explanation too
a +50 offset would be more negative and a +30 would be more positive
Old May 20, 2009 | 12:56 AM
Paul_A's Avatar
low offset = the rim sticks OUT more ex: +35 and below
high offset = the rim sticks IN more ex: +45 and up
Old May 20, 2009 | 04:04 AM
doctordoom's Avatar
Supervillain
i think you meant +50 is more positive, and +30 would be more negative. which means +50 sucks your wheel in more towards the center of the car, while +30 will make them stick out more towards the fenders (if we're talking about two wheels of the same width).
Old May 20, 2009 | 02:59 PM
mykrojas's Avatar
+1 to the posters
Old May 20, 2009 | 04:47 PM
danielg's Avatar
There's a lot more to wheel fitment than just offset. On the fit, you should be fine with that size though. During my build, I'll make a little fitment guide for those who want to know more info.
Also, those above are correct - Lower the offset, the more out the wheels go, the higher the more in. Offset is pretty much where the hub is positioned in relation to the barrel. 0 offset of would dead center of the barrel, + offset is outward, - offset is inward. I know with the GD's you also have to watch the width, as there's not a lot of space on the inners.
It's a lengthy discussion, but like I said, I'll document and take measurements on my build.
Old May 20, 2009 | 05:28 PM
Stormtrooper's Avatar
someone posted this a while back and it really helped me, wheel fitment is tricky and sometimes you have to kinda just try or take professional advice...
Wheel-Tire size comparer - RIMS-N-TIRES
Old May 20, 2009 | 06:18 PM
just so you know, i have 17x7.5 +45 on my car and they fit perfect, no rubbing or anything so you're golden!
Old May 20, 2009 | 06:28 PM
danielg's Avatar
The word "perfect" is subjective. What may be perfect fit for you, may not be perfect fit for someone else.
Got any more pics of your setup? side profile?
Old May 20, 2009 | 07:28 PM
https://www.fitfreak.net/forums/2nd-...ew-wheels.html
thats a thread i made a while ago, no sense in reposting them. i'll try and get a side profile tonight but it's raining pretty heavy right now. when i look at it from the top, it sits flush
Old May 20, 2009 | 07:42 PM
danielg's Avatar
I just checked the thread. Looks good as far as no rubbing is concerned. There's still a good 10mm to go in the rear - easy.
Old May 20, 2009 | 07:44 PM
i know
Old May 20, 2009 | 09:13 PM
AztecDude's Avatar
Smile
I like to thank you all for the help now i have a better understanding about off set's thank's again yo
Old May 22, 2009 | 08:03 AM
mahout's Avatar
Good drawings except the wheel centerline is halfway between the inside of the rim flanges rather than outside as shown. Surprisingly, not all wheels have the same flange thicknesses on both sides.
But other posts are correct, when you reduce the offset on a Fit wheel the wheel centerline pushes out from the hub so the tire gets closer to the fender arch.. The lowest offset for stock suspension is 42 mm on a wheel with 7" between flanges. 45 if you lower. And presumes tires of diameter no greater than stock (23.44" for 08, 24" for 09).
Going with wheels with lesser offsets that push the wheel further out usually means interference (rubbing) and modifying the body or fender arches.
Black3sr
Jul 1, 2013 01:32 PM
Muster
17
Jul 4, 2011 02:46 PM
Happy__Fit
Jun 16, 2010 01:19 AM
1500cc
Aug 16, 2008 04:04 AM
jedimindtricks
Aug 8, 2008 04:48 PM
