Maintenance Minder-Tire Rotation.
Old Jun 20, 2009 | 04:19 PM
Ein's Avatar
Ein
Anyone knows at what milage the tire rotation code pops up? The old schedule was 10K miles. I'm over 10K miles and still no warning.
Thanks
Old Jun 20, 2009 | 05:35 PM
Uncle Gary's Avatar
I think it comes up on the maintainence minder in conjunction with your oil change code. I think "1" is the tire rotation code. If you are changing your oil early (before 15%) and resetting the oil life meter, I suspect you won't see any other codes, so you may be on your own. Does anybody know for sure?
Old Jun 20, 2009 | 06:49 PM
Ein's Avatar
Ein
I would think the code will pop up independent of oil change. Otherwise, the MM is kind of useless. Maybe the new tire rotation is more than 10K miles?
I rotating mine at 10K miles anyway.
Old Jun 20, 2009 | 07:46 PM
Virtual's Avatar
I just rotate them when the season changes. I have a set of both summer and winter tires.
Old Jun 20, 2009 | 09:50 PM
spreadhead's Avatar
Mine codes for tire rotation on every oil change (approx 6500 miles). I use the "old" Ford schedule of rotate after the first 5000 miles on the tires, every 10,000 thereafter. Works fine for me and less work.
jlbryan027
14
Jun 30, 2015 12:16 PM
MTLian
Jun 4, 2013 04:05 AM
fitchet
Oct 18, 2010 03:23 PM
TWGE08
Jan 6, 2009 12:42 AM
wyy183
Dec 2, 2006 03:41 PM
