wheels on GE
Old Jul 9, 2009 | 09:44 AM
petee's Avatar
wheels on GE
Just wanted to ask.
What is the biggest and widest wheels that can be installed to a GE using stock springs and shocks? recommended offset for front and rear?
17 inch and 205?
My issue is that my 3 year warranty will be void if I install lowering springs or coil overs.
thanks
Old Jul 9, 2009 | 11:41 AM
cab0053's Avatar
your warranty will not be voided, unless the aftermarket thing you put in is the direct result of a problem. example: install a cold air intake and hydrolock. But I don't know where Abu Dhabi UAE is and if its weird like portugal and illegal to do any type of modding.
Old Jul 9, 2009 | 01:33 PM
BakedCookies's Avatar
United Arab Emirates
Old Jul 10, 2009 | 12:07 AM
petee's Avatar
thanks, i will keep that in mind.
Old Jul 10, 2009 | 12:14 AM
Type 100's Avatar
Originally Posted by petee
Just wanted to ask.
17 inch and 205?
thanks
17s with 205-width tire tread are good on a GE. Just not too sure of the sidewall profile.
A friend of mine ran 17x7.0 +43 RAYS G07WT wheels on his GE6 and he didn't have rubbing problems.
HTHs
Old Jul 10, 2009 | 02:17 AM
Benggolf's Avatar
Did quite a bit of reseach before deciding on the set of wheels and tires on the car right now.
We installed a set of Gram Light 57 Optimise alloy wheels (17" x 7.5" with +43 offset) and Bridgestone 205/45 x 17 tires. Added camber bolts in the front suspension and set the camber at -0.7 degrees. Absolutely no tire/fender rubbing issues even with 4 adults on board.
Old Jul 10, 2009 | 03:22 AM
Type 100's Avatar
Damn, that looks nice. Is that Gunmetal Blue? First time I've seen the color with silver and it's a better match than I imagined.
I'm looking into getting RAYS Gram Lights 57G wheels myself, same color.
Old Jul 10, 2009 | 03:34 AM
Benggolf's Avatar
Hi Type 100! It's called "light grey painted".
Check this link: Gram Lights 57Optimise Light Grey Painted
I best describe the color as grey with a bluish hue; yes, gunmetal blue is probably close.
Old Jul 10, 2009 | 04:07 AM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
Those gram lights look ****ing goooood on that GE, and keep in mind I don't even like them that much.
Old Jul 10, 2009 | 10:09 AM
Type 100's Avatar
I checked with RAYS' website - those definitely are Gunmetal Blue. RAYS ALL PRODUCTS LINE UP 2009
Tire Rack seems to rename some wheel colors.
Thanks again!
Old Jul 10, 2009 | 10:25 AM
1FiTpINOY's Avatar
There's no limit on how big of a wheel you can fit....
It all just depends on your taste and what you're going for
Old Jul 10, 2009 | 10:42 AM
Malice101's Avatar
Wish they came in a Bronze/Dark Gold...nice looking wheels Ben.
EDIT: Any chance you know the weight on em' ?
mastershake
Mar 13, 2009 03:18 AM
setter11
Jan 31, 2009 01:22 AM
BrianT
Jun 10, 2008 12:13 PM
base model 5MT
Mar 23, 2008 05:28 PM
geeq
Dec 12, 2006 07:55 PM
