Honda Homelink With No Headliner Cutting
Old Jan 28, 2010 | 11:49 AM
  #41
polokid69's Avatar
Old Jan 28, 2010 | 12:08 PM
  #42
beangrower's Avatar
yeah, i saw a couple on ebay for like 49 bucks. sucks that it costs $15 to ship ups ground...and im in hawaii so im assuming it might be double that.
thanks for the info.
Old Feb 28, 2010 | 12:49 PM
  #43
TropiTropi's Avatar
heres how i did mine, i took the wires from the grey hardness clip that came on the accord and put them on the fit clip black(ground) in the middle lt green on the corner, they fit perfectly. these wires connect to the same color wire on the green hardness and then the blue from the dome light goes to the green/red on the green hardness
Old Mar 15, 2010 | 09:58 AM
  #44
stockrex's Avatar
i have the base model and I see an impression in the headliner for the map light,
2 questions:
1. is there a wiring hardness under the headliner that I can use or tap into?
2. is there enough depth for maplight/sunglass storage combo overhead unit from say an oddy?
Old May 3, 2010 | 06:58 PM
  #45
beangrower's Avatar
Originally Posted by polokid69
So, in theory, I should be able to connect the wht/blu over to tap in to the other connector(map light) and then ground the blk wire ?
ok...so i finally picked up an odyssey homelink map light (found one on ebay for $30). sucky part was no harness so i jus fabbed up one from a computer drive. so anyways, i was wondering if it is possible to just tap the 12v power for the homelink into the maplight power wire (pink wire I believe) and just ground the black wire?
I don't want to risk shorting anything so I just thought I'd ask.
Old May 3, 2010 | 10:30 PM
  #46
stockrex's Avatar
I have read in another post ( will post link later from home pc) the OP did what you want above,
just try it outside the vehicle with a 12v powersource, also there is another post to a 12v battery conversion for the homelink,
don't forget to post some pics :-)
Old May 4, 2010 | 01:26 PM
  #47
beangrower's Avatar
okay, got it to work. here's some crappy cellphone pics. these were taken at 6am in the morning before I started work so bare with me:
so here's the computer harness/power wire from a floppy drive i believe "P4" that I used since my homelink didn't come w/ a harness. I had to trim it a little to make it fit snugly (I'm only using the home link function..i would've needed something longer width wise to access the ambient light function).
here it is plugged into the homelink:
and here is the tap into the 12v for the map lights (pink) wire...sorry for the flash. again...this is a crappy cellphone camera:
and it works:
...now its just a matter of programming it. can't wait to get rid of that ugly remote clipped onto my visor.
Old Jul 24, 2010 | 05:07 PM
  #48
Bohemian's Avatar
I got a odyssey homelink map light unit off of ebay and was hoping to use the whole unit with sunglass storage in my 2009 base. For anyone else with this hope, there is no depth for the sunglass area and the roofs metal bracket has legs that would prevent you from installing it without some bending or sawing off. I ended up just making hole for 34404-SNA-A01ZD - Map light base and using the lenses and guts from the odyssey unit. The roof head liner has an indentation on the inside that lets you know where hole edges are. I just had to feel and cut carefully.
Old Apr 21, 2011 | 11:42 PM
  #49
What The!?'s Avatar
I finally picked up a TSX unit from eBay. Has anyone figured out which wire to tap into for the ambient light function? Thanks!
Old Apr 22, 2011 | 01:18 AM
  #50
Zalthras's Avatar
Yep, Link for the lazy
Old Apr 23, 2011 | 12:07 PM
  #51
SilverbulletCSVT's Avatar
For anybody that has completed this mod. How much light output was lost with the small lenses? I really love the strong light from the huge stock Fit map lights.
_
Old Dec 30, 2011 | 05:22 AM
  #52
True Adrian's Avatar
Has anyone just tried to instal this entire part?
If so, how secure was in held in?
Old Jan 3, 2012 | 10:23 AM
  #53
FitStir's Avatar
Here's my install & all the details ---> https://www.fitfreak.net/forums/1052567-post14.html
I followed Zalthras' instructions for the connections, since I have the Navi.
Even with the existing bolts it is very secure, I did get longer bolts which I've installed and it it perfect, I will update the other thread with the part #'s soon.
Old Jan 11, 2012 | 12:51 AM
  #54
kostar's Avatar
anyone wanna sell their fit sport map lights that were removed when adding the homelink :-) :-)
Old Jan 11, 2012 | 10:21 AM
  #55
cfran55's Avatar
dang i cannot find these for that cheap on ebay.
Old Feb 9, 2012 | 02:39 PM
  #56
vietcious's Avatar
2 questions:
Planning on doing this and have the same questions... has anybody done this on their base fit? My only concerns are what type of screws we need to mount it and if a harness exists for the map light.
Thanks in advanced!
Old Feb 13, 2012 | 09:03 AM
  #57
MOTOMATT's Avatar
Question
Originally Posted by Zalthras
Harness Wiring
Connections that need to be made, two of which are pin transfers from the TSX maplight:
First we’ll start with the wiring connections that will be made between the Homelink and Maplight units themselves (Chassis GND & Intermediate GND). Flip over the maplight you just removed from your Fit.
Now put everything back together.
***IMPORTANT - Remember that the Homelink’s GND is through the mounting bolt, so test after the base is bolted back into the ceiling***
Do I connect TheTsx homelinlk Grn/red and green to the fit Blue switched ground wire ? or where do you connect the Tsx homelinlk green wire to
Old Jul 27, 2012 | 01:42 PM
  #58
Deivioncrx's Avatar
Finished mine last night. I found a 05 Accord Homelink unit in the salvage yard, it was brown so i just pained it black till i can find a grey one to match the interior. Mine is a sport w/o Navi so i ordered the Navi map lite housing from Honda, and used the light covers from the Accord unit. I didn't wire up the door switch or the ambient lite so i just removed those wires. I tapped the white/blue to the pink power for the lights, and put a ring terminal on the black and put it under the screw. Works like a charm.
Old Dec 6, 2012 | 10:14 PM
  #59
debbiemorgan31's Avatar
Question Honda Homelink With No Headliner Cutting
Awesome dude. You alone doing that? Hope i can do that to my car.
keybo
Feb 4, 2015 09:34 PM
gizmodog
Jun 10, 2013 10:26 PM
y950129
Nov 26, 2011 05:14 PM
j's_fit
Jun 21, 2010 08:30 PM
aznbigman
Jul 13, 2009 05:35 AM
