Bass is messed up on radio
Old Nov 7, 2009 | 09:26 AM
CraigK's Avatar
Has anyone experienced this? Out of the blue my bass has to be adjusted all the way down (-) to listen to the radio, etc. If left it at (0) its unbearable. Adjusting anything else has not effect. It does seem like it happen after I used an Ipod, but I disconnected it and still have the problem.
2009 Model, non-navi
Thanks, Craig
Old Nov 7, 2009 | 10:56 AM
Steve244's Avatar
I'd try disconnecting the power to the radio (pull the fuse) to attempt resetting it. Make sure you have the security code handy. Otherwise sounds like a warranty issue.
Old Nov 7, 2009 | 11:10 AM
tdesi420's Avatar
that definitely doesn't sound normal. I have to put my Bass to max (+6) just to enjoy my music.
i'd try what steve244 said or take it to the dealer.
Old Nov 7, 2009 | 03:15 PM
Shockwave199's Avatar
Just a very outside chance I know, but also try turning on/off the auto volume control thing too. Maybe that got stuck.
Dan
Old Nov 7, 2009 | 08:15 PM
Occam's Avatar
Is it a rattly sound like you've blown your speakers?
It's kind of a cheapo stereo in there - I was used to the integrated sub in the center console in my Element. The one in the Fit doesn't provide much in the way of bass. Even if you crank the bass way up in the audio settings, it doesn't boost the low end much, just muddies up the low end of the midrange and distorts the sound. It's better set even.
(Not that it makes much difference when I'm rockin' the NPR!)
Old Nov 7, 2009 | 08:40 PM
Lek's Avatar
Lek
That's normal. My Yaris was worse.
gettingfit
Jul 8, 2018 04:47 PM
jayg
Oct 21, 2010 05:44 PM
paulf5164
Sep 9, 2007 10:44 AM
rebecca
Apr 6, 2007 02:57 PM
Jimmy101
Oct 3, 2006 06:23 AM
