Cold Air Intake Suggestions
Old Dec 5, 2009 | 11:14 PM
epijimenez's Avatar
I know there have been talks about this, and i have read them through...
But can anyone suggest me which is a good intake?
PRM? K&N? Weapon-R? Takeda?
I have read the ongoing discussion about the PRM is the one that gains most HP (+7HP), but losing torque, but is it confirmed?
Also, the problems with the past generation K&N, are any of those problem present in the new one?
Read about the not-so-good reputation with the Weapon-R...
And the Takeda doesn't use the original air flow, that is installed in the Fit's hood.. I kinda don't like the cai to go under like the Takeda does...
so.. any suggestions?
Old Dec 6, 2009 | 04:37 AM
epijimenez's Avatar
i also read about the K&N Consumer Protection Pledge, which is very important to me, because im still under warranty from honda.
Old Dec 6, 2009 | 05:53 AM
Black3sr's Avatar
Why a second thread? You started the same thing a couple of days ago.
Old Dec 6, 2009 | 02:01 PM
Steve244's Avatar
Actually it was 19 days. I'm impressed by how many of you lay awake all night thinking about cold air intakes. And from such a variety of climates.
Wouldn't it be a "warm air intake" in Miami? In Canada it would be a "frigid air intake."
I'm thinking about redirecting the defroster output into the air intake on mine.
Old Dec 6, 2009 | 07:06 PM
epijimenez's Avatar
I didn't get my answer in that section... so I tried in here...
im thinking of going for the K&N just for the warranty offered and the K&N Consumer Protection Pledge...
Old Dec 6, 2009 | 11:07 PM
Vash's Avatar
i like K&N, except their filters require oil, i had a few of their intakes and i always seem to have oil going all up my pipe after i clean it. so this time i went with Pro Dry S series filter.
Old Dec 6, 2009 | 11:26 PM
epijimenez's Avatar
I already bought the K&N for $230 on ebay, brand new..
Old Dec 8, 2009 | 07:32 PM
Lyon[Nightroad]'s Avatar
Man that is some expensive hp! Why not hack together an intake from the stock air box?
Old Jan 6, 2010 | 01:00 AM
dvleucsd's Avatar
I know there was a thread about a DIY CAI or SRI somewhere, does anyone know where it is? link?
Old Jan 6, 2010 | 10:13 AM
mike2100's Avatar
Because that would look like ass and none of us are fluid dynamics engineers or at the very least have access to a dyno for guess-and-check design work.
Old Jan 6, 2010 | 10:30 AM
fitisbamf's Avatar
thats why u do somethin then go out and test it your self hahah
Old Jan 6, 2010 | 10:36 AM
dvleucsd's Avatar
Old Jan 6, 2010 | 02:43 PM
That's only for the gd. Problem with the ge8 is that you have to relocate the MAF. As for being an engineer I doubt any of the claims from the commercial companies are true about their 'superior engineering' r&d costs would be prohibitively expensive and they've already spent their budget on breasts. A SRI is not that complicated. All we are really doing is removing the air silencer (which used to be a seperate part from the filter box) and replacing it with a straight more direct intake path, which usually helps to reduce volumetric efficency losses at high rpms. The only reason Honda doesn't do this from the factory is the louder induction noise. Same with exhaust systems.
I am not a big fan of CAI's. Especially in such a small car with a cold air delivery means already in place.
Old Jan 6, 2010 | 02:45 PM
dvleucsd's Avatar
Yikes! did not know that, do you know how hard it is to relocate it?
That's only for the gd. Problem with the ge8 is that you have to relocate the MAF. As for being an engineer I doubt any of the claims from the commercial companies are true about their 'superior engineering' r&d costs would be prohibitively expensive. An Sri is not that complicated.
Old Jan 6, 2010 | 03:10 PM
I'm not really sure. I think the easiest thing to do would be to cut the maf tube out of another stock air box cover (~$25) and then couple that into any generic Sri setup like the one used for the gd only straighter. The intake location would be the same as the PRM.
Old Jan 7, 2010 | 08:24 AM
annunC8's Avatar
Are you saying you're using a Pro Dry S series filter on a K&N intake? Or are you using the Pro Dry S series all the way around? I could only find the Pro Dry for a 2009 S2000. Couldn't find one for an '09/'10 Fit.
Sorry, I'm
Old Jan 7, 2010 | 10:37 AM
IBJanky's Avatar
A cold air intake on this car would be a waste of money. It's just for looks and cool factor I guess.
I bet that the stock air box performs just as well as an aftermarket intake system.
It's not like you're going to see or feel a noticeable difference in performance. You are NOT going to go any faster. It's a 1.5L engine after all :lol:
If you really want something that will make a noticeable difference, go with forced induction. Otherwise, save your money instead.
myke
Old Jan 7, 2010 | 12:20 PM
Troubler's Avatar
myke
Agreed. And why void your warranty for something so minor?? Save it for the big stuff.
Ryan Hendrickson
Feb 21, 2017 08:59 AM
Orcshine101
Mar 22, 2013 11:55 AM
Cordizzle4life
Jan 5, 2012 11:50 AM
ride_the_pony69
May 22, 2007 11:24 PM
mikeyp6
15
May 27, 2006 05:41 PM
