TPMS question with 205/50/16
Old Mar 24, 2010 | 11:19 AM
Kyokutou23's Avatar
Hey guys I just swapped to some 205/50/16 and I now have a TPMS (sensor) light. I found on Tirerack that some people said that the Sensors needed to be reset after changing size. Does anyone know if this is true or did the mechanic just mess up a sensor when he swapped tires. Or am I just stuck and have to do to Honda a shell out $100 for them to check and reset.
Thanks for the help
Old Mar 24, 2010 | 12:57 PM
Hootie's Avatar
It is likely that they could have damaged one of the sensors whenever they were removing one of the original tires. I know whenever I had gotten new tires and my rims swapped nothing had to be reset on my GD3. Resetting the TPMS sensors is more than likely something required in higher end vehicles like a BMW 5 series or a similar type whenever you add/remove air and/or change tire size.
Old Mar 24, 2010 | 07:11 PM
JDM-Taffeta-S's Avatar
Yea i have 205 50 16 and the tpms fine im sure they cracked it when breaking the bead in the wrong place.
Old Mar 24, 2010 | 07:44 PM
Kyokutou23's Avatar
Awesome that's exactly what I was looking for.
Thanks
HermTDI
Mar 17, 2015 08:06 AM
corygibson
May 23, 2013 09:15 PM
Edison Carasio
Feb 3, 2011 03:46 AM
Itsslow
Dec 3, 2010 09:31 PM
Wolfvision
Apr 16, 2010 04:14 PM
