Wheel fitment
Old Apr 26, 2010 | 08:21 PM
Blueputtputt's Avatar
Wheel fitment
I have a 2008 fit n plan on getting some 16's on it. My question is wats
the wheel fitment? I don't want it to rub, if y'all know wat I mean.
Old Apr 27, 2010 | 12:27 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
you should have no problem with 16's.
do you know what the offset is?
also what the width is?
your car should take 4x100 if thats what
your looking for for your fitment Q?
Old Apr 28, 2010 | 02:35 AM
It's just the rims itself. The tire's I would have to get them spare. hahaha. Thanks for answer niko3257.
Old Apr 28, 2010 | 04:04 AM
qbmurderer13's Avatar
He is asking what is the offset and width of the wheels. Wheel sizes will be in this format 16 x 7.0 +40. The second number is the width, and the +X number is the offset. These numbers will decide if you rub or not. Also are you lowered?
Old Apr 28, 2010 | 04:54 AM
Type 100's Avatar
+45 offset is pretty idiot-proof. Whether stock ride height or lowered, that will definitely not rub.
Just avoid any wheel that's 7.5" or wider. 7" should be your max wheel width
Old Apr 28, 2010 | 04:39 PM
I'm not going to lower it yet, but I do hope soon. hahaha. Once i get paid at my job. the volk TE37 offset is +38 4x 114.3 and 4x100. Thank type 100 for answering my question; Thank to all of you that answer my question really a big help. off to get them now. =).... and will be posting picture as soon i get them on. =P.....
Old Apr 28, 2010 | 05:43 PM
Vanct's Avatar
+38 is pretty low and will rub unless you roll your fenders/camber it when you lower it.
Old Apr 28, 2010 | 08:08 PM
Tork's Avatar
I have 43 offset and it is fine and I am lowered. I remember BakedCookies with 42 offset and he said he rubbed (I think he also went to 205/50-16 tires).
So 43/44 might be the limit, if you are going to lower it and IF you do not want to mess with camber bolts/ rolling fenders and that sort of thing. 45 possibly a little more if you go wider tire.
Old Apr 28, 2010 | 09:09 PM
Jodele's Avatar
Dimension of 16" Accessory Wheels
this is what the 16" accessory wheel looks like
This is what a 7" rim looks like...
so, if you want 16" rims that are 7" wide, you need at least a 40-mm offset but no greater than 43-mm.
Old Apr 28, 2010 | 10:33 PM
Tork's Avatar
Well..............this does not seem right to me
You appear to be using back space, offset is different as it is offset from center. So actually a 6 or 6.5 or 7" wheel works out the same! Tires width is really the issue.
No smugness intended, strongly suggesting 43 is the minimum, and 45 or even a bit more is better if going wider tire.
And again my numbers can be fudged if you want to camper bolt/roll fenders.
Just do not want the OP to make a potentially expensive mistake, otherwise whatever people want to do to their own cars is fine by me.
Old Apr 28, 2010 | 10:59 PM
Jodele's Avatar
It is better to remain silent and be thought a fool than to speak out and remove all doubt.
[Abraham Lincoln]
Old Apr 29, 2010 | 12:55 AM
Tork's Avatar
yeah but my graphics suck compared to yours
Adam_Melton
111
Apr 16, 2023 10:12 PM
billyb
May 15, 2010 01:55 PM
Chikubi
23
Mar 30, 2009 10:13 AM
m-man@sbcglobal.net
Oct 28, 2008 01:56 AM
FireFit
Sep 13, 2006 03:38 PM
