Better Acoustics in the Tall Mode?
Old May 17, 2010 | 05:04 PM
ezesynergy's Avatar
Has anyone noticed you get better acoustics by keeping your seats folded in the Tall Mode? Since the rear door speakers are at the bottom raising your seats out of the way improves the sound.
I discovered this by accident after I had storage boxes in the back using the Tall Mode. When I removed the boxes and left it in the Tall Mode it sounded much better. The stereo does not sound the same with the seats down.
Old May 17, 2010 | 10:15 PM
Shockwave199's Avatar
I'm sure just removing the boxes opened up the sound too. I haven't tried tall mode to see but it stands to reason- if the seats are in the way they'll cut off movement too. There are some here that prescribe to having the fade setting just to the front speakers. You may want to try that too. I don't really like it set that way, but whatever makes it sound good for you is a plus!
Dan
Old May 19, 2010 | 03:19 AM
Lyon[Nightroad]'s Avatar
Technically, rear speakers are a bad thing from an SQ perspective. But, SQ is a subjective thing.
Old May 19, 2010 | 04:19 AM
Krimson_Cardnal's Avatar
What be SQ? K_C_
Old May 19, 2010 | 04:47 AM
SQ = sound quality. Another common one is SPL which is sound pressure level or loudness.
Old May 19, 2010 | 08:56 AM
Thanks Nightroad - I always like to fill in the cabin with a touch of rear fade, but I'm seeing the FIT reacts a bit differently. Not sure, but it seems like the overall response of the speaker set up is limited. Base must really suck.
I do know rear seats down kills the whole thing - gotta try seats up...
Sound is ok but it tends to need to compete with road noise off those stock Dunlop's. Too bad they weren't decent snows then I would pull them right now, but my economics just can't handle wasting 30K miles worth of rubber - it just ain't that bad. K_C_
Old Jun 9, 2010 | 02:12 PM
ezesynergy's Avatar
I've been leaving my rear seats in the Tall Mode for better SQ. I went one step further to improve the SQ from the rear speakers by moving the empty passenger front seat forward so the rear passenger door speaker has an unobstructed path towards me. You can even see the speaker when you look directly to the right. You can really hear the rear right speaker with the chair pushed forward so I set the fader to L1 to balance out the left side.
My idea won't work if you have a passenger sitting in the front.
Old Jun 9, 2010 | 02:17 PM
crash001's Avatar
Get an amp some subs and dinomatt the whole car change the hu and the speakers then u will have good sound quality lol but I also am bumping on a budget
Bengo
Dec 1, 2022 07:16 PM
FlyingHonda
Sep 27, 2012 04:09 PM
soasin
Aug 2, 2012 06:00 PM
rishio
Apr 23, 2007 09:17 AM
stacey14
May 23, 2006 03:00 PM
