Couple Questions on Maintenance
Old Jul 11, 2010 | 10:15 PM
fitowner10's Avatar
I have a 2010 Fit Sport Manual, I recently changed my oil @ 6250 miles (first time) at the dealer when the maintenance minder was still showing 40% (dealer wasn't surprised, just said I treated my car well, I was skeptical and wondered if I inadvertently reset the minder along the way). The minder was reset to 100% after the oil change. Can I still rely on it to tell me when to rotate my tires since they reset it after oil change? The rotate tires minder never came up and I am now @ 8200 miles, I am wondering if I should wait for the minder or rotate my tires now? The dealer tried to charge $25 to rotate tires, I declined. I don't have an aftermarket jack and jack stands, so I plan to take it somewhere to do the rotation (maybe walmart) Any reason I should do the rotation at the dealer? (I am a bit worried about the impact tools they use, should I?) I will try to mark and label my tires before going to make sure they do the job correctly. What's the correct rotation pattern for the Fit 10 Sport? I read somewhere that the tires and wheels look the same from the inside out or outside in, that some mechanics might put them back on reversed, is that true? thanks!
Old Jul 11, 2010 | 11:40 PM
spreadhead's Avatar
The maintenance minder tire rotation code comes up on every oil change on my '07. Personally I use the old Ford tire rotation schedule of rotate the tires at the first 5K miles and every 10K miles thereafter. Been doing this for over 30 years with good results. You only get MM codes at oil change time. If you change your oil early (I don't), you can check your upcoming codes by holding the odometer button down for about ten seconds. If you then release it and press it again for 5 seconds you will reset it. If you then do nothing it will not reset.
Old Jul 12, 2010 | 10:07 AM
spreadhead's Avatar
Originally Posted by Aviator902S
Rotate your tires front to back but not side to side, ie: do not put tires from the left side of the car onto the right side or vice-versa. This will reverse the proper tire rotational direction.
This is only correct if you have "directional" tires. For conventional tires the correct pattern (for a front wheel drive car) is to move the front tires straight back to the rear and cross the rear tires when moving them to the front. Check out these links, I think you will find a pattern.
http://www.tirerack.com/tires/tirete....jsp?techid=43
http://www.nhtsa.dot.gov/cars/rules/.../brochure.html
http://www.goodyeartires.com/faqs/Rotation.html
http://www.michelinman.com/tire-care/tire-saving-tips/
http://www.tiresafety.com/maintenance.asp
http://www.firestonecompleteautocare...s/tirecare.jsp
http://www.kumhousa.com/Basics_TireRotation.aspx
Old Jul 12, 2010 | 12:15 PM
spreadhead's Avatar
True, but I'm pretty certain all the '09 and '10 Fit Sports came with directional tires. Mine did.
All directional tires have an arrow on the sidewall denoting the rotation direction. This is clearly visible. If you don't have these arrows, your tires are nondirectional. I wasn't aware Honda used directional tires as original equipment on the Fit. Many people confuse "assymetrical" tread patterns (as on the first generation Sport's original equipment Dunlops) for "directional" tires. Assymertical tread doesn't necessarily mean "directional" tires, again look for the arrows. I'm on the way to a dealer for a part, I'll check while I'm there.
Old Jul 12, 2010 | 12:33 PM
i just look at the tires and if the fronts appear visually worn vs the rears, then i do a rotation. otherwise i dont rotate it. 7k miles is a good interval to check.
Old Jul 12, 2010 | 12:34 PM
Virtual's Avatar
Exactly what tires are those? I've never heard of OEM unidirectional tires on a Fit. Asymmetrical yes but not unidirectional.
As for rotation, I just rotate them each time I swap summer/winter tires. I know that doesn't work for everyone.
Old Jul 12, 2010 | 03:04 PM
Krimson_Cardnal's Avatar
^^DITTO^^
Every oil change....why not. That's looking like 9K...
Old Jul 12, 2010 | 03:08 PM
spreadhead's Avatar
I just checked the new Fits on the dealer's lot (three Sport, two base), none of these had directional tires.
Old Jul 12, 2010 | 03:11 PM
werd. my 09's tires are non directional.
Old Jul 12, 2010 | 03:53 PM
7K is a good time to rotate. I've always started out w/ a new set of tires to do that. Sometimes I didn't get too far...
I think when you see the wear it's a bit too far. Every 7K or with the oil.
Old Jul 12, 2010 | 08:01 PM
specboy's Avatar
I agree with whoever said pick up some jack stands. I already have a Cross tire wrench, hydraulic jack and jacks from other vehicles that I can use so rotating is easy.
I'd rotate now, then wait until the MM says next oil change then do it then.
Stick to the Maintenance Minder and you'll have no issues.
~SB
Old Jul 12, 2010 | 10:57 PM
fitowner10's Avatar
Thank you all for your responses. I was actually thinking of using my spare tire as a buffer to switch out my tires one by one, though I will certainly get a hydraulic jack and jack stands at some point. Any reason not to use the spare tire method? it would be like changing 5 tires, so it's only slightly more work.
Old Jul 13, 2010 | 01:26 AM
mole177's Avatar
It's actually a lot more work.
with a hydro jack placed between the doors on the frame, you are able to swap front to rear and rear to front in 10 minutes. If you're real good, 20 minutes for the whole job, tools back in their place and a beer. (25mins if you have to do a beer run)
jlbryan027
14
Jun 30, 2015 12:16 PM
Mikeo562
Apr 7, 2012 09:55 AM
fitchet
Oct 18, 2010 03:23 PM
crc294
Dec 4, 2009 03:25 PM
TWGE08
Jan 6, 2009 12:42 AM
