Manual Transmission, Hwy Mileage
Old Oct 10, 2013 | 09:17 AM
  #61
poorracerkid's Avatar
Returning just over 31 with 20,000 highway miles. I drive 80+ fwiw.
Old Oct 10, 2013 | 10:55 AM
  #62
over40pirate's Avatar
Yesterdays trip. Scan Gauge results.
180 miles total. 5 stops. 100 miles on interstate 60 - 70 mph. CC used on interstate. A/C used 30% of time.
Overall avg. 41.5 mpg.
Interstate no A/C tests:
60 mph 3, 6 mile tests avg. 47.0 mpg.
65 mph 4, 6 mile tests avg. 41.2 mpg.
70 mph 3, 6 mile tests avg. 39.0 mpg.
66 - 70 mph no cruise 1, 6 mile test 41.5 mpg.
Can you imagine the gas saved if they made the speed limit 55 again!
Old Oct 11, 2013 | 10:39 AM
  #63
Sprocket's Avatar
Another fillup and my figures are coming down -- more in line with what I'm seeing for other drivers.
201.1 mi on 4.772gal = 42.1mpg. Rolling 3-fill average is 46.2.
Dash display said 44.5, or 5.6% better that actual. This is the first time that my fill is worse than the display.
Used the same pump as last time and filled to the first release again.
EDIT: I haven't checked the odometer accuracy since I increased inflation pressure. If that changed the odometer it would be more distance per revolution or an odometer that shows less than the actual distance. (It had been right within a percent at 32 psi). Any odo change won't cause the whole difference in efficiency; I think I'm really getting low-to-mid 40s.
Grinder12000
Sep 26, 2012 06:12 PM
BoostTed
Dec 20, 2010 12:38 AM
phuccer
Jul 23, 2010 10:35 PM
scsi
Hawaii Community
31
May 13, 2008 05:06 AM
NMG
Aug 20, 2007 06:42 PM
