Do lights turn off automatically?
Old Mar 19, 2011 | 11:10 AM
psioux's Avatar
Originally Posted by alexcrouse
As my first post, i say you should make an article about this mod!
alright, just need to scan the headlight/exterior lights schematic at work. give me a few days.
Old Mar 21, 2011 | 10:42 PM
psioux's Avatar
Ok, this is for those that want to modify their Fit to have the light
turn on/off with the ignition switch. Bear with me, as I am new to
this forum thing.
In a nutshell, I've wired in a relay whose coil is energized by the
ignition circuit. One terminal of the coil is grounded, and the other
is attached to a "hot in the run position" wire. The switched contacts
are then wired between the light combo switch and the "micu". When the ignition is turned off, the relay opens and the micu is no longer
connected to the combo switch.
The relay does not have to be a heavy duty automotive type, since we're only switching low current logic. Just make sure the relay has a 12V coil.
I found a convenient place to splice just behind the steering wheel.
Just pry (gently) the top half of the clam shell cover to expose the
wiring to the combo switch. There's no need to remove the screws from the lower clam shell cover. Cut the black wire leading to the combo switch and attach each end to the relay contacts.
When I bought my Fit, the dealer had an alarm system installed to
secure the vehicle while they had it. I didn't buy an alarm from them,
so they simply disabled it and left it in. I removed the alarm, but left
all the splices they made. From these splices, I easily found a ground
and ignition enabled wire.
Remember, you can choose to have the relay energized in the "run" or
the "accessory" position. Its up to you.
Hope this helps.
BTW, I have pictures of the schematic and installation, but can't seem to upload them. Posting rules say no attachments. Is that rule for this thread or specific to me? Someone let me know.
Old Mar 21, 2011 | 10:49 PM
Krimson_Cardnal's Avatar
Good post, you'll be able to post pics once you've gotten a few more posts under your belt - not sure of the number. I'll rep you for a good welcome to the freakworld
Old Mar 22, 2011 | 12:04 AM
psioux's Avatar
Thanks. Too bad about pics; shows exactly where to splice.
Old Feb 14, 2019 | 10:46 AM
turfguy's Avatar
Psioux I appreciated your detailed mod...do you still have pictures? Maybe you could post them now, andinclude the specification/ make/model of the relay you used.... I am hoping to do exactly this!! Thanks
puffysweater
May 10, 2017 07:19 AM
PJ Villaflor
Jan 6, 2016 09:20 PM
SCBarren
Nov 30, 2009 10:21 PM
kevvur
20
Dec 6, 2008 03:29 PM
copilot18
Feb 13, 2008 02:15 AM
