Help Setting up a portable GPS in my Fit
Old Apr 6, 2011 | 06:26 PM
AlexCVideo's Avatar
Smile Help Setting up a portable GPS in my Fit
I just bought Garmin Nuvi 265W/265WT 4.3 inch Widescreen bluetooth Portable GPS. I have it set up on the far left of my windshield. I'm trying to figure out a good way to run the wires so it doesn't look too messy. Does anyone have any suggestions? Any pictures of their set up?
Thanks!
-Alex
Old Apr 6, 2011 | 06:45 PM
specboy's Avatar
I ran my 265W down along the edge of the door and under the fuse box door, then back up over the steering wheel and down to the 12V but that was a temp setup as it goes between two vehicles. Taking a trip this week and will be putting it back in but not sure for how long. I may try and just add another cig lighter on the left side of the steering wheel for the gps (or move it to the center for now).
~SB
Old Apr 6, 2011 | 07:43 PM
cfran55's Avatar
pics? i have a 265 also love it
Old Apr 6, 2011 | 09:21 PM
feddup's Avatar
fuse box?
hardwire it from your fusebox with one of these:
Amazon.com: Littelfuse FHM200BP ATO Add-A-Circuit Kit: Automotive
Since it's on the lower left portion of your windshield you should be able to run a wire easily up to the base of your A-pillar. It leaves your accessory fuse untouched and minimizes wire clutter.
Old Apr 6, 2011 | 10:24 PM
specboy's Avatar
I just checked and there are a bunch of hardwire kits on amazon.com's website so that and an add-a-fuse would work great.
click the V1 hardwire link in my sig for instructions on how I hardwired my valentine one. would be the same for the Garmin.
I'm adding the HW kit to my wishlist.
~SB
Old Apr 7, 2011 | 12:06 AM
cfran55's Avatar
wouldnt you lose the traffic update if you hardwire it.
Old Apr 7, 2011 | 08:16 AM
specboy's Avatar
Does the power wire have an extra antenna in it? I wouldn't think so as it can run on battery alone. Power is strictly power to the best of my knowldege and hardwiring means that you are running the power cable from the fuse box (or other location) to the back of the unit with a regular mini usb.
~SB
Old Apr 7, 2011 | 08:24 AM
cfran55's Avatar
nah the power cord has the traffic update on it, so when your on just the battery theres no traffic update
Old Apr 7, 2011 | 08:30 AM
specboy's Avatar
ahhh ok. I don't have lifetime traffic so not an issue for me... especially in VT. I wonder if it is a specialized wire or just uses one of the unused wires in the USB connection.
~SB
Old Apr 7, 2011 | 09:41 AM
cfran55's Avatar
you have lifetime traffic if you have the original power cord, which is why theres a bigger square to it, to me it doesnt really matter thoe, i usually get 1 minute or 2 minute delays nothing major so it hasnt played a big part yet
Old Apr 8, 2011 | 08:54 AM
know-nothin's Avatar
I just set mine up yesterday. Moved from a cup holder mount to side window mount. I din't use any fasteners at all--not even a zip tie. The installation is clean enough for me and works well. If you leave it plugged in like this, it will turn on and off automatically with the car ignition. I don't use the traffic feature but it should work fine as well because you are running plugged in. The only quibble I have is that the plug is too long and interferes with the cup holder a bit. Otherwise works very well and the location of the GPS is good for using while driving. I'm setting up my bluetooth to my iphone today and will try that as well over the coming days. Good luck with your setup.
1. Ran cable between panels and inside dash panel under steering wheel:
2. Threaded cable back into passenger area near door and then ran inside weather stripping.
3. Exit cable from weather stripping near side window mount and attach to unit/suction cup mount:
Edit: just paired it via Bluetooth to iPhone and went for a test drive. Works great. Speaker and mic are plenty good for my needs. No problem pairing the devices. Phone features (like address book, recent calls, etc) all came through fine.
Edit 2: I had some time today so I re-routed the cable for a neater look. See pic below. I am considering hardwiring it but this is probably good enough for me now. I also noticed the GPS gets better signal by the side window as opposed to previous location (cup holder in console by stick shift). For all those concerned about traffic updates, take note that as of 1/1/2012, MSN traffic updates will be no more. Source: https://www.msndirect.com/MSNDirectS...ouncement.aspx
Old Apr 8, 2011 | 09:28 AM
WhiskeySix's Avatar
Old Apr 8, 2011 | 09:53 AM
Whiskey, that's an awesome setup. It's a bit too much work for me and probably above my pay grade as well.
I'll have to stick with my hack for the time being.
Old Apr 8, 2011 | 02:03 PM
CasualFitOwner's Avatar
How about using Garmin Portable Friction Mount on the center of dashboard instead of setting it up on the left ?
That's what I use when I need to use GPS for traveling. Added advantage is that it's easy to hide the GPS out of the view when parked in a public parking lot. The friction grip can handle most of the turns. It only slid off toward the right (away from the driver) once, when I had to make really sharp/sudden turn.
Old Apr 8, 2011 | 02:18 PM
PatsSSMGE8's Avatar
i used a cup holder for mine and added a 12 power plug in the middle of the three switch blanks on the left side. Picture 2 above show the switch blanks I am talking about. Works well.
Old Apr 8, 2011 | 02:22 PM
I never tried it because I thought it would not adhere to dash without that glue on piece that came with it for dash mount--and I didn't want to glue anything to my dash. Good to know you thought out of the box when I was a slave to protocol.
Old Apr 8, 2011 | 07:05 PM
Goobers's Avatar
https://www.fitfreak.net/forums/general-fit-talk/57154-aftermarket-gps-setups-photos-wanted.html#post896548
It falls out every once in a while if I don't secure it (after my sister borrows it).
Old Apr 8, 2011 | 08:09 PM
Cool. Thanks for the pic.
Old Apr 10, 2011 | 03:23 PM
SenBlue09's Avatar
i actually mounted my 255 (im sure the 265w would fit) right above the front center cup holders. I used 3m adhesive velcro to mount it and it looks great, and also never need to take it off because its pretty hard to see if you look from outside. sorry no pics
Old Apr 12, 2011 | 02:28 PM
fitchet's Avatar
That's where I keep mine too...and I just use a the friction bean bag mount shoved into the cubby...it hides any wires and makes it all totally removable at any given time.
Doesn't block any windows, and I feel pretty confident just leaving it in the vehicle. When it's off, in the dark, you can't even see it.
The only drawback, might be that you have to glance down to look at it, but IMO you have to glance at it wherever you put it...and most of the time I go by "Turn by Turn" instructions...so I'm just looking at the next turn or going by the verbal instructions.
I think it's a great place to keep it, and the bean bag mount works really well placed in the space behind the center cup holders. I even have found that the "extra" bean bag...that is lying on the cup holder area, actually helps to keep cups I place in that area more stable.
nicholasG
Aug 2, 2018 11:46 AM
prhkgh
Jul 12, 2014 06:29 PM
fitandfabulous
Oct 12, 2012 12:17 PM
Brain Champagne
Dec 20, 2010 02:48 PM
runbikerun
Jan 13, 2009 01:16 PM
