amp install with stock hu
Old Apr 20, 2011 | 08:03 AM
grooveface's Avatar
Planning on installing an amp and sub. The amp I have has low level rca inputs and high level inputs. From what I hear the sound quality is better with the low level rca inputs. Should I use a line convertor off the rear speakers with the rca or just go direct into the high level inputs?
Old Apr 20, 2011 | 02:02 PM
JDM240sx's Avatar
basically what i did with mine is i used a line converter off of the rear speakers. just splice it in and your good to go, then wired the remote off of the ignition to turn off when acc is off.
Old Apr 20, 2011 | 03:49 PM
Jamy's Avatar
JDM is right. It's easiest to tap into the rear speaker wires. The Remote is easiest to just do a tap a fuse. Other than that its a piece of cake.
Old Apr 20, 2011 | 03:55 PM
Iamnotkento's Avatar
or you can just tap into the wires behind the stock HU. Since its so easy to take off which i did.
Old Apr 20, 2011 | 04:01 PM
Jamy's Avatar
That's how I did it. I just tapped the wires for the rear speakers.
Old Apr 22, 2011 | 04:33 AM
flip's Avatar
Old Apr 22, 2011 | 07:22 PM
jondotcom's Avatar
If just low range, not too much difference between hooking directly to high level vs using a high/low converter and then going into the RCA ports. I'd just skip the converter if you have a decent amp.
Wafulz
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Aug 26, 2013 02:42 AM
TunaSoda
Jul 4, 2013 12:41 PM
mdsniper7
Feb 18, 2012 07:00 PM
taffit07
May 15, 2007 01:39 PM
TomiGunz
Jul 6, 2006 07:23 AM
