When did your maintenance minder suggest changing auto transmission fluid?
Old Jun 1, 2011 | 07:33 PM
pdculbert's Avatar
I'm curious, from those who have enough miles on their fit, at what mileage did the maintenance minder suggest an automatic transmission fluid change?
I'm NOT asking when you think the fluid should be changed. I've already seen that thread.
Thanks.
Old Jun 1, 2011 | 09:14 PM
raytseng's Avatar
Thanks.
Just a complete guess but based on the EU service charts chart:https://www.fitfreak.net/forums/2nd-...tml#post795204
The Transmission is set to be changed at 60k miles so I'd assume they may set the code to come up on on the 5th oil change reminder.
Someone please reset their minder a few times in a row to prove me right or wrong.
Old Jun 3, 2011 | 05:57 PM
nickroz's Avatar
I'm pushing 63,000mi and I haven't seen the fluid service come up yet on my '08.
Old Jun 3, 2011 | 07:21 PM
JDMxGE8's Avatar
You should probably change your ATF ASAP. Just saying.
Old Jun 3, 2011 | 08:15 PM
Steve244's Avatar
Why?
Originally Posted by Owner's Manual 2009 page 251
MM code 3 ● Replace transmission fluid
Driving in mountainous areas at very low vehicle
speeds results in higher transmission temperatures.
This requires transmission fluid changes more
frequently than recommended by the maintenance
minder. If you regularly drive your vehicle under these
conditions, have the transmission fluid changed at
60,000 miles (100,000 km), then every 30,000 miles
(48,000 km). (For A/T only)
If you tow a FIT behind a motorhome, the transmission
fluid must be changed every 2 years or 30,000 miles
(48,000 km), whichever comes first. (For A/T only)
Unless it's regularly towed there's no call for it.
CommanderSlug
Nov 12, 2017 01:43 PM
ishcm
Jul 9, 2014 03:23 PM
CasualFitOwner
Sep 4, 2012 08:36 PM
Edison Carasio
Aug 20, 2009 06:08 PM
hqly
Jul 5, 2009 09:23 PM
