Interior Illumination Mod
Old Jul 22, 2011 | 12:44 PM
Steve244's Avatar
Originally Posted by Black3sr
Yes there is access at the fuse box. My lights work same as the dome. It is the two wires in middle green plug by themselves. The pink and blue ones.
There is a thread some were about hooking them up but sorry I cannot find it right now.
You do not need the Honda ambient to alter unless you want the dash switch.
Did you have to buy the plug? Or was it there already with the blue and pink wires and you tapped into these?
Do you recall if they are both hot and why there are two? I would have expected a single connection and then just going to ground. Maybe these are hot and ground (with variable resistance on the ground) to ramp the lights down the way the dome does.
Edit: found the thread (it would'a bit me if it were a snake).
Originally Posted by Zalthras
G5/G7 are the pink(+12V) and blue(GND) pins on the dome light connector in the fuse box that comes from the MICU marked below. So the footwell lights will fade out and come on just like the domelights with unlocking/locking from the keyfob and opening/closing doors.
Do your underdash lights ramp up/down in a similar fashion to the dome light, or are they just on/off?
Are your underdash lights CCFTs with a driver module?
Sorry for too many questions. Thanks for posting this. I might play some with the LEDs and resistors I have rolling around my parts box.
Old Jul 22, 2011 | 01:21 PM
Black3sr's Avatar
Go here. For whatever reason one is hot and one is ground
https://www.fitfreak.net/forums/fit-...-big-pics.html
They work same as dome light ie when you hit fob to unlock they come on and stay on til door is closed.
Are your underdash lights CCFTs with a driver module? No idea what CCFT and driver module is/are
Old Jul 22, 2011 | 01:31 PM
Steve244's Avatar
Thanks, better pics on that link. (I found the other and linked it above.)
Sorry, CCFT=cold cathode fluorescent tube. These require high A/C voltage to light and would have an external module that takes 12V to provide this.
Old Jul 22, 2011 | 01:59 PM
Black3sr's Avatar
That is what I have. Duh. Anyhow the link above to the LED strips I put on my Caravan would work and a bit easier to do. - They are here http://cgi.ebay.ca/ws/eBayISAPI.dll?...EWNX:IThttp://
Old Dec 4, 2012 | 12:56 AM
xxryu139xx's Avatar
gonna try this and drill a hole and get this lighting to be brighter
Old Dec 9, 2012 | 06:38 PM
TheFit's Avatar
Dang nice mod. Looks like ill have something to do to the fit this weekend
AtticusFit
39
Aug 2, 2020 04:18 PM
SxExCx
Apr 2, 2015 06:58 PM
Pandahh
SoCal Classifieds
Jul 21, 2014 02:52 PM
Pandahh
FittedOnEm
Sep 1, 2011 07:17 PM
