Electrical help
Electrical help
OK, I'm trying something here. I want to replace the stock hazard light with another type of push button. But I know squat about electrical. So these are the specs for the switch:
Specs:
Specs:
- LED is rated for 3 / 5 / 12v Input. Higher voltages are not tolerated
- Terminations: /28 (2.8mm tabs)
- Switching: S.P. Push to make, tactile S.P. / Latched Switch
- Max. Rating: 50mA, 24V d.c. switch
- Contact Resistance: <100m§Ù
- Insulation Resistance: >103 M§Ù
- Dielectric Strength: Contact to Panel >2.0kV
- Contact to Contact 1500V Contact
Specs:
Specs:
but... 50mA at 24V is 100mA at 12V. This is not a very robust switch (1amp is 1000mA). Your car will run at 14+ volts with the engine running (could be a problem). Just for comparison, the dome light is probably 1amp @12V (12watts). What is the switch made for? Desktop?
Even if it fits, this switch is not appropriate for automotive use. Sorry.
James Butler
Aug 15, 2018 11:49 PM
Macswfc
Dec 31, 2015 08:00 AM
