Dome Light Problems
Old Feb 23, 2012 | 04:38 PM
single_digit's Avatar
Dome Light Problems
My '09 dome light went out on me, but the bulb looks fine. I couldn't find any documentation on which fuse is specific to it, but as near as I can tell everything else (map lights, etc) seem to be working fine. Any ideas? Also, I went to autozone and they gave me the wrong bulb? Anyone know what model bulb it is (just in case it really is a bad bulb)?
Thanks!
Old Feb 27, 2012 | 03:56 AM
JAZZdatFIT's Avatar
Google/Search may be your best friend during times of distress XD
anyway i believe the fuse for the dome is #1 Back Up 10 A. there's a fuse label next to your fuse box. im pretty sure it's not a blown fuse, otherwise all your interior lights wouldn't work. correct me if i'm wrong.
also if you're looking for a replacement bulb GE8's use Part #DE3022 for the dome bulb. you can always just take the old bulb out and go match it at the store
here's a replacement guide if you need
Old Feb 27, 2012 | 08:01 AM
Yeah, I was in a rush at the auto-zone, and simply told them the model, year and that it was the dome light, but they gave me the wrong bulb. So I figured I'd ask. Map lights are working, but the dome light filament looks fine, so I'm a bit worried. Unfortunately, I just ran out of the main warranty. Oh, well. I'll check out in more detail when I have time.
Old Feb 27, 2012 | 09:02 AM
JoeB's Avatar
I had the same problem with my '09 so I tried using some light steel wool on the ends of the bulb and on the contact clips. Sometimes you need to rotate the bulb around a bit too, but that got it working again.
Old Feb 27, 2012 | 09:12 AM
malraux's Avatar
A decent multimeter would let you check continuity of the bulb and if you are getting power at the light.
MonstaMatt
Feb 14, 2026 10:10 PM
rocco005
Dec 9, 2013 02:47 PM
Billburg
Sep 11, 2011 01:27 PM
samson2112
Oct 22, 2010 07:59 PM
kleinhanz.michael@gmail.com
Sep 21, 2005 08:31 AM
