Tow Hitch
Old Apr 4, 2012 | 09:12 AM
BlueBoogers's Avatar
Tow Hitch
Does anyone with a hitch have any pictures from the underside and possibly a measurement of the center of the hitch opening to show how far it drops?
I may try to get one fitted into the Mugen rear lip.
Old Apr 5, 2012 | 09:23 PM
Rich S's Avatar
The normal frame rail hitches seem to hang below the bumper. Although I've not seen any pics of the "Valley" hitch installed yet. I'm kind of interested in it since it seems a little more hidden.
doesn't seem as sturdy but its still a tow rated hitch for the weight class.
http://www.etrailer.com/Trailer-Hitc...ey/V58630.html
edit:
here is one from Curt..... I may just make one like it and try to tuck the cross bar up higher and just drop the reciver for a more hidden look....
http://www.etrailer.com/Trailer-Hitc...eid=2012300235
Old Apr 5, 2012 | 09:30 PM
^ I'm interested to hear what you find out if you decide to tackle this project.
Old Apr 6, 2012 | 12:08 AM
Potenza's Avatar
I have the Draw-Tite hitch from eTrailer. Looking at picures of the Mugen, I don't think it would work with a lower rear apron. You could probably use some spacer plates to drop it down further from the mounting surface and use a taller ball.
I can take some measurements this weekend. I have a bunch of pictures of the install as well, just haven't had time to post up a DIY yet.
For anyone else interested; contrary to what it says you DO NOT have to knotch the bottom holes on the frame rails to insert the backing plates. There is a hole on the side of the frame rail on both sides big enough to put the plates through. You also DO NOT have to cut the plastic undertray, you can just leave it on top of the hitch surface. Everything can be installed with zero modification to the car. It's super easy to install. The wiring harness from etrailer is plug and play, also very easy, no cutting or splicing required.
Old Apr 6, 2012 | 06:11 AM
^ I appreciate any info / measurements!
Old Apr 6, 2012 | 06:54 PM
Badwrench's Avatar
I went with the Curt setup. I liked the idea of a 3 point attachment and not having the hitch go under the exhaust. I had to drill a single hole in the driver-side rail, but was super easy. Install took me about 35 minutes including running the wiring harness.
Old Apr 6, 2012 | 07:59 PM
Triskelion's Avatar
Nice post! I have the "Hidden Hitch" brand from etrailer, and it goes around, not under, the exhaust system. It attaches in the same manner as described here. There is nothing "scary" about installing a trailer hitch, and all of the brands are pretty much the same. As long as you leave the draw bar and hitch ball installed on the hitch, parking lot idiots will have a hard time causing damage to our back bumper.
Old Apr 7, 2012 | 05:47 PM
SilverbulletCSVT's Avatar
That's the same hitch I have and it goes around and under the exhaust. Under being between the exhaust and the ground not between the exhaust and the car body. That would be over the exhaust.
Draw-Tite, Hidden Hitch and Reese are all identical hitches and made by the same company.
_
Old Apr 7, 2012 | 07:23 PM
phogroian's Avatar
https://www.fitfreak.net/forums/2nd-...h-install.html
I took some measurements and installation tips for the Curt hitch on this thread.
Old Apr 7, 2012 | 09:45 PM
Thank you for the link. I may have overlooked it, but did you post any measurements from the car to the box hitch instead of from the ground?
My car is lowered so measuring from the ground isn't going to be accurate here.
hoopmatch
May 24, 2019 08:23 PM
max503
Jul 14, 2017 04:52 PM
SilverEX15
40
Jun 1, 2015 02:20 PM
SilverEX15
Feb 4, 2015 11:51 PM
ricks
Jul 12, 2010 03:39 PM
