Drop in filters
Old Apr 13, 2012 | 08:56 PM
lowkeymods's Avatar
I wouldn't spend too much money on *insert JDM brand here* unless you just want it for the name. You're not picking up any real power with a panel filter. I just got mine because I didn't want to spend $30 on an OEM one (K&N was $35 and reusable).
If you don't use a JDM filter how will you ever get mad street rep?
Old Apr 17, 2012 | 02:27 PM
FitStir's Avatar
I think I'm going to try the aFe Pro Dry S on my next change.
Old Apr 17, 2012 | 02:53 PM
Wanderer.'s Avatar
15x10 -50 wheels and a garage full of broken oil pans?
Old Apr 17, 2012 | 03:05 PM
Funkster's Avatar
I have a K&N on my Fit only because I got a good deal on it. Keep them lightly oiled and you shouldn't have any issues. I have ran many K&N filters in the past. The only reason I ever get drop in filters is to save the money on changing them.
In my experience AFE makes good products as well.
The number one thing I stress in this discussion is to remember an air filter is just that, an air filter. Remember in most, if not all cases, the increase in flow comes with a decrease in filtration capability.
I can also tell you that while "every little bit helps" that the difference in air filters on low power cars creates a very marginal difference in flow. The testing I have seen shows that the OEM style paper filter creates less than a .1 psi difference in air flow on typical small engines and can filter up to 5% better compared to higher flowing "performance" filters.
I think in the end it is up to the individual to decide if it is worth it or not. Like I said I went with it to save money and I enjoy cleaning and checking my filters personally. I also know that if an increased amount of particulates get by my filter and cause premature engine wear that I am very capable of rebuilding my engine. It will also give me a nice excuse to go forged if I ever need a rebuild.
Old Apr 17, 2012 | 09:46 PM
'12Fit's Avatar
I have run literally hundreds of thousands of miles through K&N and AFE filters. None of those vehicles used a drop of oil.
My GS400 has 160k miles on it and 120k of those were through a AFE filter (SRT intake system ECU) and I do 6-7k mile oil change intervals and it still does not use any oil.
I've got a ridiculous list of vehicles which ran aftermarket filters/intakes, not one MAF problem, no filtration related issues.
Will I Am fit.
Jun 7, 2009 01:09 PM
wk406
19
Dec 26, 2007 01:47 PM
leehom
Aug 6, 2007 04:37 AM
neotls
Jul 6, 2006 09:25 AM
sLiVeRwOrM
Jun 28, 2006 12:22 AM
