Hypermiling - Shifting gears
Old Jan 7, 2013 | 08:42 AM
  #41
SgtBaxter's Avatar
Originally Posted by SilverbulletCSVT
Something is wrong with your car or your SGII. My SGII goes to 9999 after just a few seconds coasting with my foot off the throttle in gear. _
Perhaps he's looking at it immediately after taking his foot off the gas and not waiting a few seconds?
This is why I get up to speed then take the car out of gear and coast through the rolling hills I commute. The amount of time the car would actually be using no fuel is minimal, and I'm using much much more fuel to get back up the hills as opposed to coasting and idling when I'm out of gear. It's enough of a difference to get me 36-38mpg over a tank compared to about 33 when I leave the car in gear through those sections.
Old Jan 7, 2013 | 10:45 AM
  #42
Fyrfytrryn's Avatar
Unfortunately not. I've driven with the SGII a bunch, and have the refresh rate set to fast. I coast for a good bit. Usually from the highway 138 and highway 2 intersection to almost the 10 Frwy and 215 freeway here in so cal. I'd say it's a solid 15 miles. I get to 70mph in spots. My daily commute is 160 miles total and my last fill up showed 41mpg. That's with the updated MPG meter from honda and my little paper log I keep. The SGII is right there with it, that's why I'm wondering why its not going to straight 9999.
Silverbullet, have you had your MPG meter updated by Honda? I heard the 2009's were a few % off. I had mine done and it's within a few percent. I just ask because maybe when they updated it doesn't show straight 9999 anymore.
Old Jan 7, 2013 | 11:21 AM
  #43
SilverbulletCSVT's Avatar
Yes I had mine updated but it made no difference to SGII as that pulls data straight from OBDII port not Honda mileage meter.
Set your SGII to gph meter, try again and advise back what gph's are while coasting in neutral and while coasting in gear. This will tell the tale.
I was also wondering how you got 400mpg by coasting in neutral. Now I know, coasting at up to 70mph, wow!
_
Old Jan 7, 2013 | 12:27 PM
  #44
Fyrfytrryn's Avatar
_
Will do. I just "reset to defaults" and will post up this evening after I get my commute in.
Old Jan 7, 2013 | 09:56 PM
  #45
Fyrfytrryn's Avatar
Still not showing 9999, but after the reset my milage is all weird.
Old Mar 18, 2013 | 12:14 PM
  #46
DavefromCA's Avatar
Originally Posted by Kirkuleez
Shifting at such low rpm's actually uses more gas cause you're lugging the engine. Your Fit's engine is meant to rev a little higher.
Agreed 100%, I actually mentioned this in another topic. This engine is very small and it needs those revs to make fuel efficient power, that's how Honda engineered it. That's why when your on the freeway you're pulling 3k+ rpms. Some larger cars actually benefit from more power from more cubic inches, because the motor doesn't have to work so hard to move the car.
wskwong
Jan 31, 2025 11:17 AM
ThadCastle
Jun 6, 2017 05:51 AM
CJfit15
Aug 19, 2015 03:45 PM
TheRealBenzo
Apr 8, 2010 09:34 AM
FittJedi
Mar 20, 2009 02:49 AM
