A/F guage resetting
Old May 8, 2012 | 12:00 PM
AlanZ's Avatar
A/F guage resetting
Hi guys,
I recently encountered intermittent problems of my A/F gauge restting itself when I turn on my headlights (turning on pole light does not have any problems)
These happened after I installed my HID headlights to replace my halogen (GE6).
The gauge I am using are"prosport" and it beeps whenever being resetted as it is supposed to be in silent mode.
Anyone with a clue why will this happen?
Old May 8, 2012 | 01:20 PM
DiamondStarMonsters's Avatar
Originally Posted by AlanZ
Hi guys,
Bad ground? Voltage drop is too great.
Get some beefier ground straps, a seperate fusible-link charge cable from the alternator to the battery and a voltage gauge to monitor alternator output.
The initial draw from your retro-fit headlights is putting a large strain on the rest of the system.
Check your wiring, try some of the suggestions above and get back to us
Old May 8, 2012 | 02:39 PM
Schoat333's Avatar
Is it wrong that I am wondering why you have an A/F gauge?
Old May 8, 2012 | 02:42 PM
I'm curious too.. but I figured that is one of the few mods that everyone needs first but no one actually gets.
Old May 9, 2012 | 02:51 AM
AlanZ's Avatar
Haha, you are quite right.
Initially, I wanted a guage with moving needs (for cosmetic purpose only) and thus got the A/F guage to monitor the air fuel ratio at the same time.
It is rather useless though. lol.
Old May 9, 2012 | 02:55 AM
AlanZ's Avatar
The volt readings seems constant from the batt. Tried re-joing a wire that seem loose but problem not solved.
jcrocket
Jun 22, 2018 04:36 PM
leonine
Apr 23, 2015 09:18 PM
NBPFIT07
Feb 26, 2011 05:49 PM
and1baller7k
Nov 18, 2007 05:02 PM
HTownTiburon
Aug 22, 2006 02:54 PM
