2009 Fit ignition key stuck
Old Jul 2, 2012 | 09:59 PM
jharvey's Avatar
Unhappy 2009 Fit ignition key stuck
I pulled home last night and my key would not turn all the way off. Only once I disconnect the battery can I get it to turn all the way off and get it out. Any ideas?
Old Jul 3, 2012 | 01:38 AM
kgb4187's Avatar
You have a manual or auto? Did you make sure it was all the way in park? What happened when you put the key back in to start it again?
Old Aug 1, 2012 | 05:27 PM
jharvey's Avatar
It is an automatic. I can get the key out when I disconnect the battery but other than that it just gets stuck again,
Old Aug 1, 2012 | 05:28 PM
jharvey's Avatar
I have driven it for several weeks now - (my nearest Honda dealer is about 5 hours away) I have tried wiggling it in park etc no luck so far.
Old Aug 1, 2012 | 06:39 PM
Dwalbert320's Avatar
There is a direct link between the automatic shifter and the removal of the key. worn springs or linkage in the Auto shifter will cause a problem with removing the key. That would be my first step.
Google: key stuck automatic
Old Aug 1, 2012 | 07:03 PM
Wafulz's Avatar
Fawk 5 hrs away dam bro feel bad for ya
Old Jan 17, 2013 | 09:36 AM
dmrowley's Avatar
Was ther ever any resolution on this? My FIT started doing the exact same thing yesterday. Can only get key out when battery is disconnected. Tried two different keys--same thing.
Thanks!
Old Jan 17, 2013 | 04:26 PM
x4x5x1x's Avatar
It's probably your transmission range position sensor, about $73.00 part from the dealer.
Old Jan 18, 2013 | 10:21 AM
dmrowley's Avatar
We found out a mouse has been living in the car and probably has chewed a wire somewhere. I talked to a mechanic and he thinks it has something to do with what he called the "bitsy" switch tied in with the AT shifter, I think the same thing you are referring to. Let's hope the little rat hasn't done any other damage. Thanks for the input.
Old Jun 6, 2014 | 01:42 PM
mistersink's Avatar
Check out my thread that I started recently. I haven't fixed mine yet, but I think I found what the cause is.
https://www.fitfreak.net/forums/1st-...ml#post1241316
Old Jun 6, 2014 | 01:45 PM
mistersink's Avatar
I didn't realize how old this thread was... did you find a solution?
cajunpedaler
Jul 24, 2015 03:34 AM
mistersink
Jul 31, 2014 12:38 PM
jeff_1986
Oct 30, 2011 06:26 PM
chloeishere
Nov 23, 2009 12:41 PM
cranky18
Feb 20, 2009 09:10 PM
