Manual transmission 5 speed oil pressure GE8
Old Oct 25, 2012 | 01:28 AM
CityHunter's Avatar
Hi everyone,
First post and am in need of vehicles with oil pressure sensor installed at the oil filter area. Specifically I would like for someone to have psi readings at 700rpm, 2000rpm, 2500rpm, 3000rpm, and 4000rpm.
The reason is that I have recently installed an oil bypass filter system and did not get a base line reading (before installing the bypass filter system) and would like to know what they are prior to the installation.
One more thing, does anyone have any tiny bubbles on their dipstick just after driving the car at operating temperature?
My current reading with the bypass installed runs at around 94 psi at 3000rpm
2000rpm fluctuates between 80's to 90's (psi)
Idle or around 700rpm-750rpm is from low 30's to 40's (psi)
I have seen 100+ psi with my oil sensor readings at around 2000-3000rpm but then jumps down to 90's in that rpm range.
Rpm readings are from ultra gauge.
I have been listening to the engine and checking the oil for about a week now and nothing seems to be out of the ordinary as far as listening to the engine with hood up idle and driving with no music and windows down.
These specific info would be greatly, greatly appreciated and thankful!
Wolfgang Kluge
Sep 14, 2017 09:21 AM
2007FitBLK
Sep 10, 2012 01:58 PM
Previc93
Jun 25, 2010 09:29 AM
FELIXY69
Feb 13, 2009 10:49 PM
explosivpotato
Aug 19, 2008 06:41 PM
