Resetting ABS LIGHT
Old Mar 22, 2013 | 06:26 PM
Santiad's Avatar
Resetting ABS LIGHT
Got a yellow ABS light i'd like to reset without going to Honda. Any ideas on how to do this without a HDS?
Old Mar 22, 2013 | 06:42 PM
Mini_Odyssey's Avatar
There is probably a good reason why its on, resetting it doesn't fix the problem. You can clear the code by leaving the battery disconnected for 15-20 mins and it should clear any codes, if there is a problem the light will come back on though.
Old Mar 27, 2013 | 12:15 AM
x_25's Avatar
If there is no problem the light should go off right away. If the red "break" light also is lit up, that means your break balancing is also not working (it is tied to the ABS pump in these) and you should be careful driving and look into having it serviced pronto.
Old Mar 27, 2013 | 01:27 AM
loudbang's Avatar
"BRAKE" light if you please. And "BRAKE" balancing.
Old Mar 27, 2013 | 10:16 AM
Santiad's Avatar
its a yellow ABS light that occurred when I went to a local shop to replace my wheel bearings. Afterwards I personally replaced the wheel sensors hoping the light would go away. No dice....
I was hoping to reset it to see if it lights up again. My understanding is that one the code lights up, it is saved and cannot be reset by disconnecting the battery.
Old Mar 27, 2013 | 10:44 AM
x_25's Avatar
I have heard that the wires for the rear sensors can get broken if you drop the rear suspention too far. Was it the front or rear bearings?
Vash
Jul 18, 2018 03:19 PM
RandomKoko
Jan 30, 2009 05:18 PM
RandomKoko
Jan 27, 2009 10:49 PM
Nick
Feb 27, 2006 01:06 PM
mrkrl@aol.com
May 4, 2005 11:16 AM
