how to prevent axle to pop out?
Old Apr 10, 2013 | 02:57 AM
filipinoy06's Avatar
im installing eibach pro kit pretty soon on my 2013 fit and i dont want the axle to pop out coz they said its pain in the ass when the axle popped out. so any suggestions or tricks on how to prevent axle pop out will be great. thanks!
Old Apr 10, 2013 | 08:19 AM
kudakev615's Avatar
use a bungee cord or wire coat hanger to support the whole knuckle. that way it wont allow the knuckle to move downward and pop the axle out of socket.
Old Apr 10, 2013 | 08:49 AM
solbrothers's Avatar
I've changed a few axles and I can tell you that it's quite difficult to pop the axle out. Don't be an idiot and you shouldn't have any issues
Old Apr 10, 2013 | 09:23 AM
ckipps's Avatar
^They actually slide out very easily when up on a lift without the support of the bungee or coat hanger like kudakev615 said. I learned this the hard way last week...
Old Apr 10, 2013 | 09:46 AM
im gonna try the bungee and jack tricks. thanks!
Old Apr 10, 2013 | 09:47 AM
I had a helluva time replacing my axle. What part slides out that youre having trouble with?
Old Apr 10, 2013 | 10:02 AM
ckipps's Avatar
once it angles down to a certain point without support it just slides right out.
Old Apr 10, 2013 | 11:07 AM
TW Calvin's Avatar
You can use a box or another jack or even your scissors jack to support the knuckle. Lower just enough to pull out the strut.
Some clever member used his second hydraulic jack he had to aid in the install after the spring was replaced.
Old Apr 10, 2013 | 11:20 AM
mahout's Avatar
Yea, verily. Letting the hub flop out is definitely not good practice unless you like re-insertyibg the axle. Good bungee works best for us.
Old Apr 10, 2013 | 11:28 AM
kudakev615's Avatar
Correct, to be clear we are not talking about the axle popping out of the transmission. With out supporting the knuckle the inner cv joint will slid out of alignment and binds up. I did the same thing ckipps when I installed my coilovers last week too haha.
Old Apr 10, 2013 | 02:40 PM
Wanderer.'s Avatar
I used floor jack to hold it up and then it can double to raise and lower everything without strain. Was very cautious after reading the problems on here. Just don't go berserk when pulling stuff out and be careful.
Old Apr 10, 2013 | 05:24 PM
^^ +1 wat wandererererer said. i too use my 2nd hydraulic to lift the arm up. im getting older now and im tired of putting extra work for something my tools can help me on.
pretty soon my kids can do the installs for me. lol
Old Apr 11, 2013 | 01:08 PM
SilverbulletCSVT's Avatar
Using wire zip ties go around axle at each side of the CV. Then with more zip ties connect both sides allowing some movement but not enough to allow it to slide out. Kinda like a loose cage. I'll search for a photo and post it up later.
_
Vash
May 7, 2025 12:41 AM
skytree
May 18, 2015 12:45 AM
teamkitty
Nov 15, 2010 09:49 PM
413FIT
Aug 30, 2009 07:57 PM
petwhookie
14
Apr 30, 2008 08:25 AM
