Fit cargo cover window frame clips. Need!
Old Jul 25, 2013 | 03:07 PM
DigitalDude65's Avatar
I just received a cargo cover, but it's missing the window frame clips. Can anyone help me locate the part number for these clips or recommend a workaround?
Thanks.
Old Jul 25, 2013 | 03:48 PM
RAH's Avatar
RAH
It doesn't stay in place without them? I just looked at my Honda-made cover and the cover itself seems to be in the same hooked shape as the plastic clips that are attached to that area. In other words, it looks as though the "hook" shape of the cover itself in that area would hold it in place pretty well, although of course it wouldn't "snap" into place the way the plastic clips do. But maybe it is dangerous to have it unsecured?
A work-around might be a paper-clip or thin wire that went thru the cover (make a small hole), and then went around the big plastic knob on the car frame where the clip clips.
Old Jul 25, 2013 | 03:55 PM
MPA's Avatar
MPA
it will stay in place without them, but the clips are needed to that it can raise up with the hatch when opened.
The last post in this thread has a part # (84405-SF4-003), but I could not find a picture
https://www.fitfreak.net/forums/2nd-...placement.html
Old Jul 26, 2013 | 05:42 PM
komafit's Avatar
Old Jul 27, 2013 | 11:18 AM
That's it! You are the MAN!
Old Jul 27, 2013 | 01:17 PM
RAH's Avatar
RAH
Oh, I see now. I was referring to a different area (under the cover where it attaches to the car body on each side, where a plastic "clip" grips a knob on the car). Glad you found what you were looking for (and only $2!!).
Old Jul 28, 2013 | 08:04 AM
specboy's Avatar
I had the same issue with mine when I got them for Christmas. E-mailed the Seller (amazon marketplace) and they sent the clips out ASAP at no charge. That said, $2 would have been more than acceptable to me.
~SB
Ferndaleguy
Aug 30, 2020 06:56 PM
2012FitFan
Dec 22, 2013 09:04 PM
WangLung
Oct 17, 2012 08:37 AM
cspan37421
Aug 24, 2012 11:17 PM
FAZER
Mar 6, 2012 01:12 AM
