Does my a@# look small?
Old Aug 2, 2013 | 03:40 AM
Black3sr's Avatar
Having a Taffy it was easy to give a different look by painting the diffuser. Maybe a white one on yours?
You wiper needs a massage to give it a "stiffy"
Old Aug 2, 2013 | 06:10 AM
singhonwheels's Avatar
Originally Posted by 1SickVeilsideZ
Sexy as Fawk
is this thing bagged ?
looks great IMO
Old Aug 2, 2013 | 06:14 AM
1SickVeilsideZ's Avatar
Yup, he's on air.
Old Aug 2, 2013 | 11:13 PM
j1nNju1c3's Avatar
Originally Posted by lowkeymods
Wish this was an option...good mix of sport and subtle:
Guess I could start a groupbuy with JDP, but it's a pain in the arse getting people to put their $ where their mouth is...no pun intended.
That is actually pretty ideal. IF the fins were a wee bit longer, then it's cake.
The question is, how much would this cost from JDP?
Old Aug 3, 2013 | 01:43 AM
Goobers's Avatar
I don't consider this subtle... unless you're talking to someone that can't tell the difference between our Fit and a Hummv.
As for filling out the arch... the only real way is to lift it back up to stock height (or higher) and get bigger diameter tires. Of course, you end up with a lifted look.
Well, there is one other way... fabricate some "extension" sheet metal to make a smaller arch (with the focus right where the center of the wheel is). Not sure how doable that is.
Or maybe something like a "wide body" kit (though, maybe not so wide?!?) with a purposely made smaller arch.
Old Aug 3, 2013 | 02:21 AM
BMW ALPINA's Avatar
A JDM RS bumper with Mugen JDM RS rear under spoiler might give you the proportion that you are looking for, and here are the pictures in black color similar to your car:
If you want the side skirt and the rear under spoiler to look like they have same height,
then you use standard USDM side skirt in combination with JDM RS rear bumper + Mugen RS rear under spoiler like this picture here:
and this one here:
because if you also add Mugen Side Skirt,
then the Side Skirt from Mugen which is lower then USDM standard side skirt
will again make the car look similar to stock where the side skirt are lower then the rear bumper lowest point (in reference to the ground),
like this picture below:
Old Aug 3, 2013 | 01:05 PM
lowkeymods's Avatar
Hmmm...all good suggestions. JDP I'm sure would make a J's style if we can get 10 buyers up front. Running the JDP duckbill groupbuy was a lot of work though.
The JDM rear conversion makes sense but also a lot of work...guess it's mugen or suck it up and start the groupbuy.
Old Aug 3, 2013 | 01:27 PM
BMW ALPINA's Avatar
First of all, getting 10 people to actually commit to buy (and willing to place deposit) for a J's style group buy is virtually impossible from my point of view.
Because our GE8 model is about to be replaced by a new generation model,
and GE8 had been around for years, so most likely the enthusiasm had gone down. (notice this forum had been quiet and more quiet each day)...
not many people here had as much enthusiasm for modifying GE8 anymore (to the level that you want to do with that rear bumper).
now for the JDM Rear Conversion,
Actually the JDM Rear Conversion is NOT a lot of work.
First of all, you need to take it to the body shop anyway since
when you buy a used (but like new) JDM RS Rear bumper most likely you have to paint them to match your car color since they again most likely is not in the same color as your current car color.
Second, all the body shop had to do is to chop / shortened the 2 legs of the rear reinforcement bar beam so they became closer to the chassis of our car. again not chop the rear reinforcement bar it self but chop it's leg.
The price for Painting and doing this modification for the rear reinforcement bar beam usually maximum around $700 at a decent body shop. (I did mine for $650).
If you want (dare) to make it simpler, just took out those reinforcement bar (they are attached only by bolts to the chassis).
In The Rest of The World (outside US), no Honda Fit or Jazz have any reinforcement bar anyway, so most likely the chassis of USDM Fit already
have a built in reinforcement bar and that extra reinforcement bar that we had is just a "redundant" devices required by US certification law.
The different is, if you took out those reinforcement bar then you just have to make a small welding modification to the rear exhaust hanger,
since for USDM, the rear exhaust hanger are on the "extra" reinforcement bar and not at the chassis.
If you do it this way, I think the cost will just involve painting and little welding for the exhaust hanger, any body shop should be able to do this for just $500 or maybe maximum $600.
The other significant cost will be the cost of "reliable" shipping for a used JDM RS rear bumper from Japan ...
Here is my thread about this conversion that I had done:
https://www.fitfreak.net/forums/2nd-...t-version.html
no metal body panel need to be modify or change or painted for the rear JDM RS conversion.
Trust me, it is so easy (well, any body shop should find this easy)
Old Aug 3, 2013 | 02:29 PM
mrphilip's Avatar
Damn it! Found this:
Guess even the Mugen won't close the discrepancy between the side and rear height.
The Mugen side skirts sit lower than the OEM Sport side skirts. The OEM Sport side skirts flow really well with the Mugen rear, which is why I didn't buy the Mugen side skirts. The side profile shot that 1SickVeilsideZ posted up is a great example of the OEM Sport side skirts with the Mugen rear.
Old Aug 4, 2013 | 12:15 PM
redsun's Avatar
I really am happy with my car's progress, but I'm not sure about the rear from a side profile. I'm not sold on the Mugen or JDP rear lip/diffuser and really wish there were other under spoiler options.
Am I being picky or does the rear look like it needs a little something to lower/beef it up visually? Ideas?
What the! Your car looks great! Also, the title of this thread made me LOL! "Does my a@# look small?" I was just imagining my GF asking me that! "Well, er, ehh..."
Old Aug 4, 2013 | 01:17 PM
connor55's Avatar
Rear mudflaps could be a cheap way to go. Though they won't fill out the entire rear, they'll height match from a side view with the side skirts. You could even get them painted to match like I did.
Old Aug 4, 2013 | 01:35 PM
  #32
Wanderer.'s Avatar
JDM RS rear. That Mugen rear is so unfortunate with the dual exhaust, idk what they were thinking it's like the project was unintentionally misdirected from the Accord V6 design department and ended up on the wrong desk.
Personally I think your car looks awesome as-is and I would do nothing.
Old Aug 4, 2013 | 03:13 PM
  #33
lowkeymods's Avatar
The Mugen isn't bad...it's just a little more "loud" than what I'm going for.
Think I'm going to sit on it for a while, maybe Mugen waaaay down the road, for now I'm going to leave it.
Old Aug 22, 2013 | 09:57 AM
  #34
jdmjunkie561's Avatar
Depends on angle I guess. Can't find a good side profile of my car.
OMG you care is TITS
Old Aug 22, 2013 | 01:41 PM
  #35
Bama3Dr's Avatar
Originally Posted by MTLian
Maybe you could hang some bull testicle ornaments from the tow hook for added style... I kid, I kid...
The guys at work thought of that idea also to "man up" my Fit. But, they said it would need to be goat testicles so that the scale size would be correct.
-Dustin
Old Aug 22, 2013 | 11:10 PM
  #36
fujisawa's Avatar
I like the original OP pic. It looks better than any stock Fit and better than any aftermarket junk. Good job.
I think the Mugen modification would ruin it. That rear valance just says, "I wanted to impress people who know that both exhausts are fake and just think it's cool to spend lots of money on cosmetic changes so I look like I have Japanese-market bad taste"
If you're antsy, take a pic of your car and stretch the pic in Photoshop by 105% horizontally. You'll be very happy
Old Aug 23, 2013 | 01:09 AM
  #37
Thanks man I appreciate that! Your fit is one of many that has inspired me along the way to mod mine up. I'm about to get real deep into my car, more then I thought I ever would.
Back on topic, either way you go lowkeymods your car is clean and very tastefully done.
macbuddy
17
May 7, 2015 12:10 AM
alanchan
21
Nov 17, 2010 09:25 PM
JFit317
Sep 3, 2010 12:47 AM
fork_nSpoon
Jan 6, 2010 11:05 AM
jani88
May 29, 2008 11:19 AM
