GE Rear bump stops
Old Sep 25, 2013 | 09:16 AM
Longlivetheking's Avatar
GE Rear bump stops
Hey guys and gals , I have a GE on dropzones springs
The ride is great ! I like the drop, but I didn't cut the rear bump stops for the sake of time ! My question is , if I did cut them would it lower the rear a little more or would it just give me a better ride ? Thanks
Old Sep 25, 2013 | 09:53 AM
Wanderer.'s Avatar
It won't lower your car any unless it's sitting on the bumpstops rested, which I'm sure it isn't, or at least I hope not haha
It will improve your ride if you are bottoming out on them a lot. How much drop do the springs give?
Old Sep 25, 2013 | 10:30 AM
The front 2 the rear 1.8. But I've only gotten about 1.2 for the rear that's what's thought was maybe the bump stops are causing it to not settle correctly ?
Old Sep 25, 2013 | 10:43 AM
Also the right side is about a 1/4 inch taller than the left should I just put something heavy in the boot to help it settle ?
Old Sep 25, 2013 | 03:51 PM
Wanderer.'s Avatar
1.8" isn't enough to be sitting on the bumpstops, so that's not the problem. There isn't a whole lot of weight on the back of the Fit so the springs may just need a little time to settle. Also check to make sure the springs are sitting in the perches correctly.
Old Sep 26, 2013 | 02:56 AM
Goobers's Avatar
Personally, I'd just leave it alone. Even after it settles, the driver side will still be lower (cause... there's a driver). That is, unless you plan on carrying around extra weight for the life of the spring (which would be... pointless).
After about 50k miles or so, pull the springs and swap left <-> right sides.
fit419
3rd Generation GK Specific Suspension & Brakes Sub-Forum
Apr 3, 2016 04:17 PM
dekayfit
Dec 2, 2013 10:52 AM
lsdbaby
Nov 4, 2012 10:29 PM
pwnstar
Oct 15, 2008 09:27 PM
hmgFIT
Nov 22, 2007 03:13 PM
