Using Navigation as Monitor for Back-up Camera
Old Dec 22, 2013 | 02:29 PM
jmed999's Avatar
Arrow Using Navigation as Monitor for Back-up Camera
Has anyone been successful at using the navigation screen as the backup camera monitor?
Thanks!
Old Dec 23, 2013 | 11:33 AM
FitStir's Avatar
I don't think too many Fit owners have done it.. if you want to do it on the OEM nav, you'll need a Navtool, or something similar. But there's mixed reviews about that...
check this thread for more info:
Originally Posted by FitStir
According to Navtool there's a different models for the 09-11's as opposed to the 12-13's --> Honda FIT interfaces
Here's a DIY on the previous version which required to splice/remove the old screen ribbon, and install the Navtools ribbon... Read the whole DIY it explains it all --> DIY: Add Auxilary Video Inputs to Display Custom Video on Stock Navigation Screen - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
The new version of Navtool, does away with that step, and the install is much easier.
After your done intalling the Navtool, you can install a game system, DVD, etc and use the inputs on the Navtool. Here's the same guy's DIY on the back up camera DIY: Add Backup Camera for Reverse Camera Display on Factory Nav Screen - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
One of the members in that thread said the unit/install was a nightmare and decided to take it out, and replace the Nav with an aftermarket unit that does those features (probably the best choice).
Old Dec 23, 2013 | 12:23 PM
Rbneron's Avatar
Curious why you would need a back-up camera on a car as small as the Fit.
Old Dec 23, 2013 | 01:56 PM
Shockwave199's Avatar
^^ I've heard that question before. I don't think it's the size of the car at all. A bus or a fit- the more you can see the better. I manage without one but recently I'm having a harder time actually turning my head to the extremes to confirm all areas behind me are clear. So now it's a physical limitation. I won't do anything for the Fit but my next car you bet- BU cam for sure.
Old Dec 23, 2013 | 09:34 PM
connor55's Avatar
I have the jvc kwnt 700 navi system with a video aux in jack. It's pretty easy to run the aux cable from the back of the navi to the inside of the trunk hatch. You might need to drill a small hole behind the liscense plate area to run the cable into the camera. As for the camera itself, I just got mine from best buy.
Old Dec 23, 2013 | 09:47 PM
Rampo's Avatar
I have the Clarion NX501. I mounted the camera inside the car and then ran the wire through the center mount stop light opening and fed it through the flexible rubber wire guide that goes between the top of the hatch on the left side, and down into the cavity where all the tail light wiring is located.
https://www.fitfreak.net/forums/2nd-...ml#post1134264
Old Dec 25, 2013 | 12:22 PM
jmed999's Avatar
Thanks for the replies guys! The last 2 cars I've owned have had a backup camera and I've gotten pretty used to it. Once you use one for a while it's hard to do without,
SilverEX15
Dec 16, 2017 05:46 PM
ADVphotography
Oct 27, 2014 11:25 AM
Shockwave199
Feb 22, 2013 11:42 PM
vbearvbear
Jun 2, 2009 10:02 PM
thr3
Sep 19, 2007 02:13 PM
