16x7 rpf1 +35
Old Feb 25, 2014 | 04:48 PM
SiRca90's Avatar
16x7 rpf1 +35
Anyone running rpf1s with +35 offset with 205/45 or larger tires. Looking for a set for autocross and don't want to run smaller than a 205 tire. Read on here that some people are running +35 and its rubbing the brake calipers. HELP please!!!
Old Feb 25, 2014 | 09:13 PM
De36's Avatar
Did you already buy a set of 35off?
Old Feb 25, 2014 | 09:20 PM
SiRca90's Avatar
Not yet going to pick them up when taxes get back. Right now I'm just looking at what will work with min and max offset. I really want to run the 35 offset.
Old Feb 25, 2014 | 09:21 PM
De36's Avatar
Why 35?
10char
Old Feb 25, 2014 | 09:25 PM
SiRca90's Avatar
Why 35?
10char
I was looking at 48 but l'm really just looking to find what works better with the 215/45/16 tires I'm wanting to run for autox
Old Feb 25, 2014 | 09:28 PM
De36's Avatar
My street wheels are 17x7 40off 205/45. I was rubbing a little over hard bumps on lowering springs. I installed camber bolts and roll center adjusters and I don't rub at all.
The set up you want to run is very similar to mine. The only diff is yours in .2" closer to the fender... Which is negligible.
I run the rpf1 16x7 43off for the track.
Old Feb 25, 2014 | 09:31 PM
De36's Avatar
There aren't many tire choices in 215/45 esp no autoxing worthy. You're better off with a 205 semi-slick. More grip and lighter for autoxing. I have these, havent run them yet so I don't have a review.But they are cheap enough.
595 RS-R RACING - OnlineTires.com
More $$$
http://www.tirerack.com/tires/tires....13674x012-tire
Old Feb 25, 2014 | 09:32 PM
SiRca90's Avatar
Right on. Where did you pick the camber bolts and roll center adjuster at I'm looking to get some because I currently have 205/50/16 on the car and I rub the shit out of my fenders.
Old Feb 25, 2014 | 09:35 PM
SiRca90's Avatar
Do you rub on the inside of the wheel well during hard cornering?
De36's Avatar
I bought camber bolts from Napa $35~40. A few companies make roll center adjusters aka extended ball joints.
https://www.fitfreak.net/forums/2nd-...t-install.html
Old Feb 25, 2014 | 09:38 PM
De36's Avatar
No I dont. Your set up will be further away. I have set of 225/50r16 for the track, I have to remove the fender liners for trackdays.
Old Feb 25, 2014 | 09:47 PM
SiRca90's Avatar
I've seen the ball joints, been thinking about getting them. Yeah I've had to remove my fender liners also.
Old Feb 26, 2014 | 04:29 AM
singhonwheels's Avatar
running 195 55 on 15x7 +35 offset, camber bolts at front, minor fender mods lowered on s tech (1.6 inch drop).. and i dont rub whatsoever.
195 55 15 tyre is taller than 205 45 16.. so i hope u should be fine using camber bolts, and rolled fenders.
Old Feb 26, 2014 | 11:43 AM
SiRca90's Avatar
Is anyone running the camber shims in the rear or is it not really necessary?
Old Feb 26, 2014 | 04:51 PM
De36's Avatar
^^^ On a FWD less camber in the rear is desired, than the front. In order to need more rear camber; you would have to run ~2+ degrees in the front. 2+ degrees is a track type set up, not a DD. On a DD 1~1.5 degrees is desired in the front to maintain good tire wear.
So depending what you are running up front depends on what you run in the rear to balance the car. On a DD the rear is fine as is.
Old Feb 26, 2014 | 05:28 PM
SiRca90's Avatar
I have got to say thank you De36. You have truly been very helpful. Ill be picking up the front camber kit here shortly along with the extended ball joints.
Old Feb 26, 2014 | 07:36 PM
HB1320's Avatar
I have 16x7 +35 of a GD3 no rubbing and brakes are cleared too no issues
Old Feb 26, 2014 | 07:39 PM
HB1320's Avatar
Btw IM running 205/45/16
08_vbp_fit
Dec 16, 2016 01:56 PM
Stay_Fitted
Jul 22, 2013 09:45 AM
spootnik
Aug 26, 2012 07:30 AM
Pmpn8ez05
Oct 5, 2011 12:00 AM
HB1320
Apr 29, 2009 01:49 PM
