2013 Fit rear cargo light
Old May 4, 2014 | 05:28 PM
pabyfield's Avatar
Noone could tell me anything about the rear cargo light which cannot be shut off so the hatch can be left open...or forgotten to be closed. I found that the light goes off after 15-20 minutes if the hatch is open. Not even Honda could tell me this. Close and reopen the hatch and it's back on. Wish it had a switch, however
Old May 4, 2014 | 06:20 PM
DaveFL's Avatar
Problem for me was that it was too dim to see anything, switched to led and brighten things up. Same for the map lights.
Old May 5, 2014 | 06:34 AM
fittmann's Avatar
Cargo Light Switch
"Switch" out the standard light for one from an Acura. If I'm, not mistaken, the P/N is: 34265-SFE-003. Easy no-tools-needed swap, works great. A replacement lense that has a switch built-in. Hope this helps!
'12 VBP Sport w/minor appearance & comfort mods!!
Old May 5, 2014 | 07:45 AM
Rampo's Avatar
I can confirm the part number referenced by fittmann. I bought two from Bernardi Honda; one for my daughter's GD, and one for my GE. Easy plug & play installation, took about two minutes each.
Old May 9, 2014 | 01:52 PM
Mkidd3's Avatar
Did mine yesterday and changed out all interior bulbs to LED's. I can finally see in the car!
Old May 9, 2014 | 08:45 PM
Gingervitisman's Avatar
Definitely doing this, thank you for the part number
littleblackcar
Jun 8, 2018 10:38 AM
secondspassed
25
Aug 30, 2017 12:39 AM
SleepyNyte
Jan 29, 2011 11:02 PM
Fit4Pits
Aug 28, 2009 11:28 PM
Special
May 23, 2008 05:05 PM
