2010 Fit Sport MT 100k Maintenance Question
Old Sep 16, 2014 | 12:04 PM
Texture's Avatar
I am coming up on 100k miles in my 2010 Fit Sport MT and was wondering if there are any specific maintenance activities that need to be done at this milestone such as spark plug replacement, radiator fluid, rear drum brakes, etc.
I have recently had the MT transmission fluid replaced and planning to get a new battery but should I be thinking about anything else (not including tires, disk brakes, and oil changes)?
Also, the car did not throw any maintenance codes yet - not sure if I should wait for those or be more proactive?
Thanks so much for any input.
Old Sep 16, 2014 | 12:12 PM
Wanderer.'s Avatar
These plus valve adjustment and brake fluid change if you haven't done it (3 years recommended service life)
Drum brakes are probably fine, but you could pull the drum and inspect just for piece of mind.
Old Sep 16, 2014 | 03:15 PM
Steve244's Avatar
I'd wait until the MM calls for it. It will call for a valve clearance check at the same time and it's not cheap.
Old Sep 16, 2014 | 03:20 PM
Texture's Avatar
Thanks guys. Do you know what the approx cost for spark plug replacement and this valve clearance check
Old Sep 16, 2014 | 03:32 PM
Steve244's Avatar
my best guess is around $400. Let us know if you get a quote. Also it doesn't hurt to negotiate. I think it's about 2.5 hours labor and $80 parts.
Old Sep 16, 2014 | 03:36 PM
Texture's Avatar
Does the spark plugs replacement alone cost around $400 or is that for both spark plugs and valve clearance check?
Old Sep 16, 2014 | 03:48 PM
Wanderer.'s Avatar
That's for both, approximately.
Most of the cost is the labor time, since you need to remove a decent amount of stuff to actually get to the spark plugs (by the book anyway) and to adjust the valves.
I've gotten quotes as low as $250 for the valve adjustment and plugs, it just depends on the shop.
Old Sep 16, 2014 | 04:54 PM
Texture's Avatar
I would imagine doing this at the dealership would be on the higher end of that expense scale
Old Sep 16, 2014 | 07:40 PM
hspatz's Avatar
Spark plug replacement and valve clearance adjustment is not real hard to do. You just need normal mm sockets and a feeler gauge. if you search, you will find very good instructions for DIY on this site. If you have straight feeler gauges, you should bend them up with pliers to fit them properly.
You can do this job if you can do your own brakes and oil changes and have a basic understanding of how the valve train operates. Allow 4 hr. I did not need any new gaskets. Use only OEM spark plugs--NGK I believe. You can get them at Rockauto.com at a decent price.
sarasube
Jun 29, 2018 10:10 AM
ge813sport
Nov 18, 2017 08:34 PM
panthers
Dec 19, 2013 02:05 AM
madtodaimax
Sep 4, 2012 11:01 PM
Bman98SL2
Apr 12, 2012 01:33 PM
