Simple interior lighting fix?
Old Jan 1, 2015 | 08:08 PM
keybo's Avatar
Just bought 2010 Fit base. Looking for a simple way to have a map light.
Kinda dark and I have old eyes.
Any suggestions will be much appreciated. Thanks.
Old Jan 1, 2015 | 08:33 PM
siguy's Avatar
Quick & cheap is to buy a LED type little flash light. Store it in glove box or one of the cubby holes. I use one all the time - bright light and easy to read maps or whatever. Got mine at the dollar store.
Old Jan 1, 2015 | 08:37 PM
keybo's Avatar
Excellent idea. Thanks!
Old Jan 1, 2015 | 08:40 PM
DrewE's Avatar
There are a couple of threads here for the searching about putting in a set of map lights from the sport model, which can either be ordered as spare parts or probably found used from a junkyard. There is a little work involved in putting them in, but nothing too complex. I gather the trickiest parts were neatly cutting the headliner (so the fabric doesn't look pulled) and fishing wires from the dome light over. The factory wiring harness for the base doesn't have the wires for the map lights.
Simpler implies something along the lines of a flashlight or possibly something that plugs into the lighter jack. There are many little flashlight-like lamps made with clips and bendable arms, often advertised as book lights or music stand lights or similar. They would probably work well.
Old Jan 1, 2015 | 08:43 PM
keybo's Avatar
Thanks, I shall investigate.
Old Jan 30, 2015 | 02:05 PM
JKID's Avatar
if your using the original light bulbs swich to led bulbs buy from ebay search size it will put out bright white light versus yellow dim original bulbs
Old Jan 30, 2015 | 04:01 PM
mahout's Avatar
back when we were rallying we used a light plugged into cig lighter. for our computer we dualled the cig lighter plug-in. both are avaiable in aftermarket stores. don't think they are more than $6.
Old Feb 4, 2015 | 09:34 PM
sean.haynes's Avatar
The dome and map light use a festoon base lamp.
You can purchase an LED off the web and swap it out.
It seriously improved the brightness and area covered inside my car.
its also takes about 2 mins to swap
gizmodog
Jun 10, 2013 10:26 PM
TwoFits
Feb 2, 2013 08:13 AM
y950129
Nov 26, 2011 05:14 PM
j's_fit
Jun 21, 2010 08:30 PM
bensenvill
Aug 11, 2009 03:17 PM
