Is this the right hole to run an amp power cable? Warning: bad quality photo inside
Old Jan 18, 2015 | 09:50 AM
Jas101's Avatar
Ive given up trying to find an amp i can power internally, ive decided to go 'all in' and go directly to the bateery. Can anyone one confirm that this is a whole i can go through ( ive been looking all afternoon for holes described in other threads).
I was trying to find the one described by member 'feddup'.
Thanks for any help.
Edit: left hand drive 2009 jazz ( european fit)
Old Jan 18, 2015 | 08:49 PM
xxryu139xx's Avatar
man can't even tell what you took a picture of. anyway what I did with mine was take a long flathead and push it from the inside through where the gas pedal wire harness goes into the firewall. then go to your engine and look at where it's sticking out. u can also electrical tape your power wire to the flathead and then just pull it through the other side... easier if u have ur stock airbox out.
Old Jan 19, 2015 | 04:53 AM
Jas101's Avatar
The bottom left is the clutch rod. I was outside for and hour yesterday, my guide ( enourmous tiewrap) dissapeared bthrough the hole but i couldnt find it in the engibe bay. Im going to use the passenger side seal instead.
Thanks for the reply.
ck42
May 12, 2017 08:22 PM
GotFitB13
41
Mar 17, 2015 07:30 PM
iFit08
15
Mar 12, 2011 12:41 PM
Perrenoud Fit
Oct 12, 2010 11:52 PM
12vltfrk
Sep 30, 2009 08:10 PM
