Door power lock not working. Actuator?
Old Apr 14, 2015 | 01:04 AM
Stupendous's Avatar
I have a 2011 with 50K miles.
My right rear passenger door will not lock or unlock using the key or the lock switch on the driver side door. The actuator makes no noise.
At ~$120 for the part (72610-TF0-J01) I want to make sure it's the actuator. Is there any sort of diagnostic I can do? Can I apply +12V and ground to the actuator (momentarily) and see if it locks? The only issue is I do not know what pins are what on the actuator. The wires on the plug are green, black, yellow, sky blue'ish.
Thank you
Old Apr 14, 2015 | 02:52 AM
Black3sr's Avatar
Here you go
Old Apr 14, 2015 | 10:51 PM
Stupendous's Avatar
Thank you for posting that. Nothing happened when applying +12V and ground so off to order the part.
Old Apr 15, 2015 | 06:35 AM
Black3sr's Avatar
You're welcome.
Old Apr 28, 2015 | 04:56 PM
hspatz's Avatar
Alternative
I would suggest testing the solenoid with an ohm meter. If open (infinite resistance) then replace. If there is resistance, then maybe the solenoid is stuck and you could free it up and grease it instead of replacing it.
gkitf16
17
May 4, 2026 07:57 PM
dongetti
Jan 22, 2024 10:05 AM
teamkitty
Jan 24, 2021 09:33 PM
wutangben
Jan 19, 2020 05:18 PM
09Fitter
Jan 14, 2015 02:12 PM
